StephenCWLL
Oct 08, 2016Aspirant
This firmware file is incorrect!
Whether I ask the router to download the firmware itself or if I upload the correct firmware file, I get the same "This firmware file is incorrect!" message. I'm currently on V1.0.1.88 and trying to ...
- Retired_MemberOct 16, 2016
I guess you'll have to live with it or relace it.
The WNR2200 has been EOL'ed. There is currently no replacement product.
Retired_Member
Oct 08, 2016when you downloaded file did you extract it before trying to use it? 6,017KB is what I got after extracting it.
- StephenCWLLOct 09, 2016Aspirant
Yes, i unzipped it and pointed it at the .img file when it asks for the firmware file.
- michaelkenwardOct 09, 2016Guru - Experienced User
Tried a second download? That can fix some broken retrievals.
- StephenCWLLOct 16, 2016Aspirant
No difference :(
