StephenCWLL
Oct 08, 2016Aspirant
This firmware file is incorrect!
Whether I ask the router to download the firmware itself or if I upload the correct firmware file, I get the same "This firmware file is incorrect!" message. I'm currently on V1.0.1.88 and trying to ...
- Retired_MemberOct 16, 2016
I guess you'll have to live with it or relace it.
The WNR2200 has been EOL'ed. There is currently no replacement product.
StephenCWLL
Oct 09, 2016Aspirant
Yes, i unzipped it and pointed it at the .img file when it asks for the firmware file.
michaelkenward
Oct 09, 2016Guru - Experienced User
Tried a second download? That can fix some broken retrievals.
- StephenCWLLOct 16, 2016Aspirant
No difference :(
- michaelkenwardOct 16, 2016Guru - Experienced User
It is not unknown for Netgear to have misfiled firmware on its system.
If what you have works, stick with it.
- michaelkenwardJan 27, 2018Guru - Experienced User
By the way, the most recent version is 1.0.1.102
WNR2200 Firmware Version 1.0.1.102 | Answer | NETGEAR Support
Find it on the product's support pages.
