whitedp's avatar
whitedp
Tutor
Apr 10, 2022
This IP Should Be Blocked For ALL SERVICES. Is it?
Hello and thanks in advance for any help. I have an IoT device that I wish to restrict to only my LAN. To do this in my R6400, I have used the admin pages under Security to Block Services. I have specified that for the device (192.168.1.37) I want to block ALL (this is TCP/UP and ports 1-65535).
Then I started to capture packets to confirm this is working as expected. The attached image shows an excerpt from the Wireshark display where I have filtered on the device's IP. It "appears" to my un-educated mind, that there is a "conversation" taking place between 192.168.1.37 and 52.53.61.98. I am not sure but this appears to be trying to created a TLS channel between the 2 IPs.
Seeing ANY RESPONSE coming from 52.53.61.98 is surprising and potentially concerning to me as I would have thought that any communication with the remove computer on this IP would never be seen since all outbound communications should be blocked.
But again, I am un-educated and so really do not know what I am doing/seeing. So if you can clarify this or enlighten me, it is appreciated.
Thanks
1 Reply
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi whitedp, we'd like to know the following
    May we know what type of device this is?
    Is there a way to interface with it and confirm if it is accessing the Internet (other than the Wireshark log)?
    You can try setting the same thing up for a device you can easily confirm with (ie. smartphone) to see if the function works.
    Dexter
    NETGEAR Team
