DocMagnus
Jan 15, 2022Aspirant
Three routers behind one modem - How to?
Hi all, I'm looking for a netgear solution if one exists to my problem. I have been given a /252 in addition to my static IP on an NBN service. So I have 3 static IP addresses assisgned to my conne...
wcalifas
Jan 16, 2022Prodigy
Why don't you just run one router with the modem as the main router and the other 2 routers as access points coming off the main router once you turn off their dhcp?
DocMagnus
Jan 16, 2022Aspirant
Because in doing so they will have IP addresses assigned by the first router - which is not what I want. I don't want to daisy chain routers as I need each router to have an external address - using what my provider has given me. I either need a single netgear box to be:
NBN modem and router for all 3 IP addresses
OR
Use the existing NBN modem provided in bridge mode and then use either 1or 3 netgear routers behind it - but not daisy chained, as I need each to have a public IP address.
