sueb223's avatar
sueb223
time restrictions - WNDR4500v2
Problem with time restrictions through live parental controls netgear genie, WNDR4500v2, on a Mac Yosemite 10.10.5 Set a time restriction for 11:00pm-5:30am but wifi stays shut down till 9:30am. Thoug...
  • antinode's avatar
    Sep 04, 2017
    > [...] Thought it might be a time zone issue
       Sounds like it.
    >  though under administration it says north america.
       Under where, exactly?
    >  Don't know if there's a place to put EST.
       According to the User Manual, ADVANCED > Security > Schedule : Time
    Zone.
       Start at http://netgear.com/support/ , put in your model number,
    select Documentation, download the User Manual, and look for "time
    zone"?
