see3ducks
Oct 13, 2017Aspirant
too old?
ref model WGR614v9 serial # 1SV2887H02BEA I keep trying to post a question. It says to correct the highlighted areas and try again. However there are NO highlighted areas. Next I tried to con...
- Oct 13, 2017
> [...] Is the noise from the AC adapter or the router? [...]
> The hash or the birdies of course stop when the power is removed.
Still not clear. I'll assume that the router itself is the noise
source. (A bad AC adapter would normally be an easier thing to
replace.) There could be some inductor with loose coils which a drop of
goop would fix, but who knows?
> I wonder what the power requirements are. I doubt I can find the
> manual anymore.
Labels on the router and the AC adapter should reveal their
requirements and/or ratings.
> The Netgear router has been very good to me - I mean look at the age.
Perhaps only newer models get bug-ridden firmware updates.
see3ducks
The hash or the birdies of course stop when the power is removed. All I did (so far) is disconnect to power plug in the back of the router leaving the power source intact. However, I would "think" that would leave the source without a load and perhaps shift the switching rate (guess) of the source.
Have I opened it up yet? Not yet. I'm an ex techie so it's no problem.
How long? I first noticed it probably a year ago but honestly it probably may have been acting up much longer. I just started my detective routing.
I wonder what the power requirements are. I doubt I can find the manual anymore.
Thanks !
antinode
Oct 13, 2017Guru
> manual anymore.
- see3ducksOct 13, 2017Aspirant
Thank you !
- wcalifas831Oct 14, 2017Prodigy
The power adapter you need is a 12volt with 1000mA or 1A which are equivalent. Sound like it's a capacitor making that squealing noise. Try a power adapter of that voltage and see if that solves it.
- michaelkenwardOct 14, 2017Guru - Experienced User
Generic power supplies work fine with Netgear devices. Have to, Netgear doesn't sell spares.
And check the +/- polarity.
Some generic transformers come with a bunch of tips and with a polarity switch.
