cmemomitt
Nov 17, 2020Aspirant
TP-Link - Archer AX6000 Dual-Band Wi-Fi 6 Router - Black
I have nighthawk, but heard the connections don't persist. Is the TP-Link - Archer AX6000 Dual-Band Wi-Fi 6 Router - Black a better choice? Is it hard to setup/maintain? Need reliable WIFI...
Nov 17, 2020Guru - Experienced User
You're on a Netgear forum asking about how a TP-Link performs?
Maybe it'd be better directed at the tp-link forum.
cmemomitt
Nov 18, 2020Aspirant
Thank you for your kind reply.
I am KEEPING my CM1200 modem.
I want to change out the router and wanted feedback on that. Make sense?
This forum cannot answer?
Appreciate reply.
- plemansNov 18, 2020Guru - Experienced User
The CM1200 is a solid choice in modem. I've used tplink devices before but none recent. You're going to see more people with netgears on here than tp-link .Which is why i directed you to the tp-link forum for questions about how well their devices work
