floriann
Apr 27, 2014Aspirant
Trek PR2000 DHCP-problems, keeps dropping connections, maybe workaround
Hi! Some days ago I bought the new Netgear Trek PR2000 mobile wireless router. Purpose was to have an AP for all my devices while traveling and being able to connect them to a hotspot or hotel wifi...
- Mar 22, 2016
hksteve I would like to inform you that the fix is now available in our download page.
Feel free to update your firmware and provide feedback.
Thanks!
FelixZ
Nov 01, 2015Aspirant
I can confirm the same experience. If you connect multiple devices and then disconnect one, the router will drop connection to all devices. And I thought the point of this device was to be able to share a single WiFi connection... I really hope that the fix mentioned in an earlier post will be released soon in a new firmware. Otherwise, I'll have to return this device where it came from. That would be a shame, because I see a lot of potential if the router was actually useable.
tjdoherty33
Nov 02, 2015Aspirant
I've given up hope on a resolution for this issue and am returning my Trek to Amazon. Luckily, they are allowing me to return two of them since the first one was outside of their standard return policy.
One primary purpose I had for the Trek was to use the ethernet port to connect a device which was not equiped with a wireless adapter nor could a USB adapter be used. When the Trek wasn't working, I shared a wireless connection from one of my spare laptops, and it worked great.
Unfortunately, because of this experience, this has been my first purchase of a Netgear device and my last. The issues I've experience with the Trek are so bizarre that I cannot see myself recommending any of Netgear’s product line to anyone I know.
