floriann
Apr 27, 2014Aspirant
Trek PR2000 DHCP-problems, keeps dropping connections, maybe workaround
Hi! Some days ago I bought the new Netgear Trek PR2000 mobile wireless router. Purpose was to have an AP for all my devices while traveling and being able to connect them to a hotspot or hotel wifi...
- Mar 22, 2016
hksteve I would like to inform you that the fix is now available in our download page.
Feel free to update your firmware and provide feedback.
Thanks!
bru2basics
Jan 25, 2016Aspirant
I've just received one of these routers from amazon for review and can tell straight away it's has the issue with dissconeting. Ps3, android, windows 7 and everytime a device joins or leaves the network in ap mode it reboots. I want to know if it's worth my time registering to get hold of the beta firmware or if I just return it now and leave feedback with amazon?
- OliverWiJan 25, 2016Initiate
Yes, it's definetely worth it! I have just finished a 4 days test run with the BETA firmware V1.0.0.14_1.0.2 and I can say that it just works. There was no single reboot or unexpected disconnection of a WiFi device. The PR2000 was connected to the power socket and to my main WiFi router for more than 80 hrs.
IMHO it's time to release this firmware to the public!
- bru2basicsJan 25, 2016Aspirant
Ok thanks for posting back. How do I go about getting this firmware to test?
- ElaineMJan 25, 2016NETGEAR Employee Retired
bru2basics Make sure your device is registered. In this way, we can create a case number for you.
Let me know once done.
Thanks!
