floriann
Apr 27, 2014Aspirant
Trek PR2000 DHCP-problems, keeps dropping connections, maybe workaround
Hi! Some days ago I bought the new Netgear Trek PR2000 mobile wireless router. Purpose was to have an AP for all my devices while traveling and being able to connect them to a hotspot or hotel wifi...
- Mar 22, 2016
hksteve I would like to inform you that the fix is now available in our download page.
Feel free to update your firmware and provide feedback.
Thanks!
uomonero91
Feb 12, 2016Aspirant
Hi,
I bought my device on 1st of February and I have the same problem that I red in this thread.
I use my PR2000 in Router Mode and I need it because my computer hasn't an ethernet port, so with this device I should take advantage to use ethernet connection that is better than wifi connection in my accommodation.
But it lost connection and my PR2000 reboot every two minutes after connection with my PC, therefore only one connection at time.
It's useless.
I saw that the BETA FW version make this device more stable than the latest stable release, if you can send me this version I can try it.
I look foreward for your support.
Regards
"NETGEAR PR2000 FW V1.0.0.14_1.0.1"
