Some days ago I bought the new Netgear Trek PR2000 mobile wireless router. Purpose was to have an AP for all my devices while traveling and being able to connect them to a hotspot or hotel wifi.
Configuration was fine and I was able to connect to my home network in wireless client mode. My home router is a TP-Link TL-WR1043ND running OpenWrt 12.09 Attitude Adjustment, wifi with WPA2-AES, serving DHCP.
The Trek was able to connect and the whole system was running. Unfortunately I realized, that the Trek kept dropping connections every 3-5mins with the annoying Netgear genie popping up and trying to reestablish a connection. Sometimes it worked, later on the Trek failed to connect at all.
Since I read that OpenWrt Attitude Adjustment might be having problems with certain wifi connections, I upgraded my WR1043ND to Barrier Breaker. The connection drops continued, especially under OSX nearly every minute. The WR1043ND showed various DHCP- and wifi-failed-to-acknowledge-errors in its log.
After trying all possible setting changes in the Trek-config (and shortly before returning the Trek), I found something like a workaround. In the Trek-config I disabled the DHCP-Server for the LAN-zone and assigned static IPs to the connecting clients. Well at least until now this seems to be working fine. No more dropped connections, no more annoying genie popping up and trying to reconnect, the whole system seems to be working.
But at the moment I'm kinda confused about the reason. In my understanding, the Trek connects to a hotspot and gets an IP-address assigned by the hotspot-DHCP. Then the Trek uses NAT to connect the attached clients to the internet. Actually the DHCP-IP-addresses assigned by the Trek to the clients connected to the LAN-zone shouldn't affect the DHCP-settings of the hotspot-network at all. Normally the private IP and DNS-settings are just for the private client LAN, aren't they? If I'm not completely wrong with my assumption, there might be a bug in the DHCP-server of the Trek or the way how dynamic IPs of the client LAN are handled. Starting from the point where I changed to static IPs in the client LAN, there were no more error messages in the log of the WR1043ND.
Strange thing... Maybe someone could correct me if my assumptions are wrong? Btw, I'm using the Trek PR2000 stock firmware (which is something like 1.0.0.9) since there's no other available.
Thanks."},"Conversation:conversation:427505":{"__typename":"Conversation","id":"conversation:427505","solved":true,"topic":{"__ref":"ForumTopicMessage:message:427505"},"lastPostingActivityTime":"2016-03-23T07:35:55.891-07:00","lastPostTime":"2016-03-23T07:35:55.891-07:00","unreadReplyCount":185,"isSubscribed":false},"ModerationData:moderation_data:427505":{"__typename":"ModerationData","id":"moderation_data:427505","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"Revision:revision:427505_1":{"__typename":"Revision","id":"revision:427505_1","lastEditTime":"2014-04-27T03:20:09.000-07:00"},"ForumReplyMessage:message:427509":{"__typename":"ForumReplyMessage","id":"message:427509","conversation":{"__ref":"Conversation:conversation:427505"},"author":{"__ref":"User:user:148600"},"entityType":"FORUM_REPLY","eventPath":"category:home-wifi-routers/category:home-networking/category:English/community:ejquo23388board:home-wifi-routers-general/message:427505/message:427509","revisionNum":1,"uid":427509,"depth":1,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:home-wifi-routers-general"},"subject":"Re: Trek PR2000 DHCP-problems, keeps dropping connections, maybe workaround","readOnly":false,"editFrozen":false,"showMoveIndicator":false,"moderationData":{"__ref":"ModerationData:moderation_data:427509"},"parent":{"__ref":"ForumTopicMessage:message:427505"},"body":"Yes, tried to set to disabled, but it doesn't work for me. Running quite unstable. Any suggestions?","body@stringLength":"99","rawBody":"Yes, tried to set to disabled, but it doesn't work for me. Running quite unstable. Any suggestions?","kudosSumWeight":0,"repliesCount":0,"postTime":"2014-05-22T12:55:21.000-07:00","images":{"__typename":"AssociatedImageConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"attachments":{"__typename":"AttachmentConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"timeToRead":1,"currentRevision":{"__ref":"Revision:revision:427509_1"},"latestVersion":null,"metrics":{"__typename":"MessageMetrics","views":14850},"read":false,"visibilityScope":"PUBLIC","isEscalated":null,"placeholder":false,"originalMessageForPlaceholder":null,"messagePolicies":{"__typename":"MessagePolicies","canModerateSpamMessage":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","key":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","args":[]}},"canReply":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.forums.action.message.reply_to_entity.allow.accessDenied","key":"error.lithium.policies.forums.action.message.reply_to_entity.allow.accessDenied","args":[]}},"canAcceptSolution":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.accepted_solutions.action_allow.message.mark_as_accepted_solution.accessDenied","key":"error.lithium.policies.accepted_solutions.action_allow.message.mark_as_accepted_solution.accessDenied","args":[]}},"canRejectSolution":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.accepted_solutions.action_allow.message.unmark_as_accepted_solution.accessDenied","key":"error.lithium.policies.accepted_solutions.action_allow.message.unmark_as_accepted_solution.accessDenied","args":[]}},"canTag":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.labels.action.labelableentity.set_labels.allow.accessDenied","key":"error.lithium.policies.labels.action.labelableentity.set_labels.allow.accessDenied","args":[]}},"canEdit":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.forums.action_allow.edit_message.accessDenied","key":"error.lithium.policies.forums.action_allow.edit_message.accessDenied","args":[]}},"canKudo":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.kudos.action.entity.give_kudos.allow.accessDenied","key":"error.lithium.policies.kudos.action.entity.give_kudos.allow.accessDenied","args":[]}}},"customFields":[],"replies":{"__typename":"MessageConnection","edges":[],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}}},"CachedAsset:theme:customTheme1-1759225537395":{"__typename":"CachedAsset","id":"theme:customTheme1-1759225537395","value":{"id":"customTheme1","animation":{"fast":"150ms","normal":"250ms","slow":"500ms","slowest":"750ms","function":"cubic-bezier(0.07, 0.91, 0.51, 1)","__typename":"AnimationThemeSettings"},"avatar":{"borderRadius":"10px","collections":["default"],"__typename":"AvatarThemeSettings"},"basics":{"browserIcon":{"imageAssetName":"Browser_Icon-1697787492229.PNG.png","imageLastModified":"1697787496004","__typename":"ThemeAsset"},"customerLogo":{"imageAssetName":"NETGEAR_Community-1744420932835.png","imageLastModified":"1744420934427","__typename":"ThemeAsset"},"maximumWidthOfPageContent":"1600px","oneColumnNarrowWidth":"800px","gridGutterWidthMd":"30px","gridGutterWidthXs":"10px","pageWidthStyle":"WIDTH_OF_BROWSER","__typename":"BasicsThemeSettings"},"buttons":{"borderRadiusSm":"3px","borderRadius":"3px","borderRadiusLg":"5px","paddingY":"5px","paddingYLg":"7px","paddingYHero":"var(--lia-bs-btn-padding-y-lg)","paddingX":"12px","paddingXLg":"16px","paddingXHero":"60px","fontStyle":"NORMAL","fontWeight":"700","textTransform":"NONE","disabledOpacity":0.5,"primaryTextColor":"var(--lia-bs-white)","primaryTextHoverColor":"var(--lia-bs-white)","primaryTextActiveColor":"var(--lia-bs-white)","primaryBgColor":"var(--lia-bs-primary)","primaryBgHoverColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) * 0.85))","primaryBgActiveColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) * 0.7))","primaryBorder":"1px solid transparent","primaryBorderHover":"1px solid transparent","primaryBorderActive":"1px solid transparent","primaryBorderFocus":"1px solid var(--lia-bs-white)","primaryBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","secondaryTextColor":"var(--lia-bs-gray-900)","secondaryTextHoverColor":"hsl(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), calc(var(--lia-bs-gray-900-l) * 0.95))","secondaryTextActiveColor":"hsl(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), calc(var(--lia-bs-gray-900-l) * 0.9))","secondaryBgColor":"var(--lia-bs-gray-200)","secondaryBgHoverColor":"hsl(var(--lia-bs-gray-200-h), var(--lia-bs-gray-200-s), calc(var(--lia-bs-gray-200-l) * 0.96))","secondaryBgActiveColor":"hsl(var(--lia-bs-gray-200-h), var(--lia-bs-gray-200-s), calc(var(--lia-bs-gray-200-l) * 0.92))","secondaryBorder":"1px solid transparent","secondaryBorderHover":"1px solid transparent","secondaryBorderActive":"1px solid transparent","secondaryBorderFocus":"1px solid transparent","secondaryBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","tertiaryTextColor":"var(--lia-bs-gray-900)","tertiaryTextHoverColor":"hsl(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), calc(var(--lia-bs-gray-900-l) * 0.95))","tertiaryTextActiveColor":"hsl(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), calc(var(--lia-bs-gray-900-l) * 0.9))","tertiaryBgColor":"transparent","tertiaryBgHoverColor":"transparent","tertiaryBgActiveColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.04)","tertiaryBorder":"1px solid transparent","tertiaryBorderHover":"1px solid hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","tertiaryBorderActive":"1px solid transparent","tertiaryBorderFocus":"1px solid transparent","tertiaryBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","destructiveTextColor":"var(--lia-bs-danger)","destructiveTextHoverColor":"hsl(var(--lia-bs-danger-h), var(--lia-bs-danger-s), calc(var(--lia-bs-danger-l) * 0.95))","destructiveTextActiveColor":"hsl(var(--lia-bs-danger-h), var(--lia-bs-danger-s), calc(var(--lia-bs-danger-l) * 0.9))","destructiveBgColor":"var(--lia-bs-gray-200)","destructiveBgHoverColor":"hsl(var(--lia-bs-gray-200-h), var(--lia-bs-gray-200-s), calc(var(--lia-bs-gray-200-l) * 0.96))","destructiveBgActiveColor":"hsl(var(--lia-bs-gray-200-h), var(--lia-bs-gray-200-s), calc(var(--lia-bs-gray-200-l) * 0.92))","destructiveBorder":"1px solid transparent","destructiveBorderHover":"1px solid transparent","destructiveBorderActive":"1px solid transparent","destructiveBorderFocus":"1px solid transparent","destructiveBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","__typename":"ButtonsThemeSettings"},"border":{"color":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","mainContent":"DARK","sideContent":"DARK","radiusSm":"3px","radius":"5px","radiusLg":"9px","radius50":"100vw","__typename":"BorderThemeSettings"},"boxShadow":{"xs":"0 0 0 1px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.08), 0 3px 0 -1px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.08)","sm":"0 2px 4px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.06)","md":"0 5px 15px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.15)","lg":"0 10px 30px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.15)","__typename":"BoxShadowThemeSettings"},"cards":{"bgColor":"var(--lia-panel-bg-color)","borderRadius":"var(--lia-panel-border-radius)","boxShadow":"var(--lia-box-shadow-xs)","__typename":"CardsThemeSettings"},"chip":{"maxWidth":"300px","height":"30px","__typename":"ChipThemeSettings"},"coreTypes":{"defaultMessageLinkColor":"var(--lia-bs-link-color)","defaultMessageLinkDecoration":"none","defaultMessageLinkFontStyle":"NORMAL","defaultMessageLinkFontWeight":"400","defaultMessageFontStyle":"NORMAL","defaultMessageFontWeight":"400","defaultMessageFontFamily":"var(--lia-bs-font-family-base)","forumColor":"#2D242D","forumFontFamily":"var(--lia-bs-font-family-base)","forumFontWeight":"var(--lia-default-message-font-weight)","forumLineHeight":"var(--lia-bs-line-height-base)","forumFontStyle":"var(--lia-default-message-font-style)","forumMessageLinkColor":"var(--lia-default-message-link-color)","forumMessageLinkDecoration":"var(--lia-default-message-link-decoration)","forumMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","forumMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","forumSolvedColor":"#148563","blogColor":"#1CBAA0","blogFontFamily":"var(--lia-bs-font-family-base)","blogFontWeight":"var(--lia-default-message-font-weight)","blogLineHeight":"1.75","blogFontStyle":"var(--lia-default-message-font-style)","blogMessageLinkColor":"var(--lia-default-message-link-color)","blogMessageLinkDecoration":"var(--lia-default-message-link-decoration)","blogMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","blogMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","tkbColor":"#4C6B90","tkbFontFamily":"var(--lia-bs-font-family-base)","tkbFontWeight":"var(--lia-default-message-font-weight)","tkbLineHeight":"1.75","tkbFontStyle":"var(--lia-default-message-font-style)","tkbMessageLinkColor":"var(--lia-default-message-link-color)","tkbMessageLinkDecoration":"var(--lia-default-message-link-decoration)","tkbMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","tkbMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","qandaColor":"#4099E2","qandaFontFamily":"var(--lia-bs-font-family-base)","qandaFontWeight":"var(--lia-default-message-font-weight)","qandaLineHeight":"var(--lia-bs-line-height-base)","qandaFontStyle":"var(--lia-default-message-link-font-style)","qandaMessageLinkColor":"var(--lia-default-message-link-color)","qandaMessageLinkDecoration":"var(--lia-default-message-link-decoration)","qandaMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","qandaMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","qandaSolvedColor":"#3FA023","ideaColor":"#FF8000","ideaFontFamily":"var(--lia-bs-font-family-base)","ideaFontWeight":"var(--lia-default-message-font-weight)","ideaLineHeight":"var(--lia-bs-line-height-base)","ideaFontStyle":"var(--lia-default-message-font-style)","ideaMessageLinkColor":"var(--lia-default-message-link-color)","ideaMessageLinkDecoration":"var(--lia-default-message-link-decoration)","ideaMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","ideaMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","contestColor":"#FCC845","contestFontFamily":"var(--lia-bs-font-family-base)","contestFontWeight":"var(--lia-default-message-font-weight)","contestLineHeight":"var(--lia-bs-line-height-base)","contestFontStyle":"var(--lia-default-message-link-font-style)","contestMessageLinkColor":"var(--lia-default-message-link-color)","contestMessageLinkDecoration":"var(--lia-default-message-link-decoration)","contestMessageLinkFontStyle":"ITALIC","contestMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","occasionColor":"#D13A1F","occasionFontFamily":"var(--lia-bs-font-family-base)","occasionFontWeight":"var(--lia-default-message-font-weight)","occasionLineHeight":"var(--lia-bs-line-height-base)","occasionFontStyle":"var(--lia-default-message-font-style)","occasionMessageLinkColor":"var(--lia-default-message-link-color)","occasionMessageLinkDecoration":"var(--lia-default-message-link-decoration)","occasionMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","occasionMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","grouphubColor":"#333333","categoryColor":"#949494","communityColor":"#FFFFFF","productColor":"#949494","__typename":"CoreTypesThemeSettings"},"colors":{"black":"#000000","white":"#FFFFFF","gray100":"#F7F7F7","gray200":"#F7F7F7","gray300":"#E8E8E8","gray400":"#D9D9D9","gray500":"#CCCCCC","gray600":"#949494","gray700":"#707070","gray800":"#545454","gray900":"#333333","dark":"#545454","light":"#F7F7F7","primary":"#000000","secondary":"#333333","bodyText":"#504B51","bodyBg":"#EFF4F9","info":"#409AE2","success":"#41C5AE","warning":"#FCC844","danger":"#D13A1F","alertSystem":"#FF6600","textMuted":"#707070","highlight":"#FFFCAD","outline":"var(--lia-bs-primary)","custom":["#FFFFFF","#EFF4F9","#00B9FF","#6C717A","#26E880","#002FFF","#2F353F","#12171E","#085E4F","#001D9E","#986943"],"__typename":"ColorsThemeSettings"},"divider":{"size":"3px","marginLeft":"4px","marginRight":"4px","borderRadius":"50%","bgColor":"var(--lia-bs-gray-600)","bgColorActive":"var(--lia-bs-gray-600)","__typename":"DividerThemeSettings"},"dropdown":{"fontSize":"var(--lia-bs-font-size-sm)","borderColor":"var(--lia-bs-border-color)","borderRadius":"var(--lia-bs-border-radius-sm)","dividerBg":"var(--lia-bs-gray-300)","itemPaddingY":"5px","itemPaddingX":"20px","headerColor":"var(--lia-bs-gray-700)","__typename":"DropdownThemeSettings"},"email":{"link":{"color":"#0069D4","hoverColor":"#0061c2","decoration":"none","hoverDecoration":"underline","__typename":"EmailLinkSettings"},"border":{"color":"#e4e4e4","__typename":"EmailBorderSettings"},"buttons":{"borderRadiusLg":"5px","paddingXLg":"16px","paddingYLg":"7px","fontWeight":"700","primaryTextColor":"#ffffff","primaryTextHoverColor":"#ffffff","primaryBgColor":"#0069D4","primaryBgHoverColor":"#005cb8","primaryBorder":"1px solid transparent","primaryBorderHover":"1px solid transparent","__typename":"EmailButtonsSettings"},"panel":{"borderRadius":"5px","borderColor":"#e4e4e4","__typename":"EmailPanelSettings"},"__typename":"EmailThemeSettings"},"emoji":{"skinToneDefault":"#ffcd43","skinToneLight":"#fae3c5","skinToneMediumLight":"#e2cfa5","skinToneMedium":"#daa478","skinToneMediumDark":"#a78058","skinToneDark":"#5e4d43","__typename":"EmojiThemeSettings"},"heading":{"color":"var(--lia-bs-body-color)","fontFamily":"Outfit ExtraLight","fontStyle":"NORMAL","fontWeight":"600","h1FontSize":"40px","h2FontSize":"36px","h3FontSize":"32px","h4FontSize":"28px","h5FontSize":"24px","h6FontSize":"22px","lineHeight":"1.3","subHeaderFontSize":"14px","subHeaderFontWeight":"500","h1LetterSpacing":"normal","h2LetterSpacing":"normal","h3LetterSpacing":"normal","h4LetterSpacing":"normal","h5LetterSpacing":"normal","h6LetterSpacing":"normal","subHeaderLetterSpacing":"2px","h1FontWeight":"var(--lia-bs-headings-font-weight)","h2FontWeight":"var(--lia-bs-headings-font-weight)","h3FontWeight":"var(--lia-bs-headings-font-weight)","h4FontWeight":"var(--lia-bs-headings-font-weight)","h5FontWeight":"var(--lia-bs-headings-font-weight)","h6FontWeight":"var(--lia-bs-headings-font-weight)","__typename":"HeadingThemeSettings"},"icons":{"size10":"10px","size12":"12px","size14":"14px","size16":"16px","size20":"20px","size24":"24px","size30":"30px","size40":"40px","size50":"50px","size60":"60px","size80":"80px","size120":"120px","size160":"160px","__typename":"IconsThemeSettings"},"imagePreview":{"bgColor":"var(--lia-bs-gray-900)","titleColor":"var(--lia-bs-white)","controlColor":"var(--lia-bs-white)","controlBgColor":"var(--lia-bs-gray-800)","__typename":"ImagePreviewThemeSettings"},"input":{"borderColor":"var(--lia-bs-gray-600)","disabledColor":"var(--lia-bs-gray-600)","focusBorderColor":"var(--lia-bs-primary)","labelMarginBottom":"10px","btnFontSize":"var(--lia-bs-font-size-sm)","focusBoxShadow":"0 0 0 3px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","checkLabelMarginBottom":"2px","checkboxBorderRadius":"3px","borderRadiusSm":"var(--lia-bs-border-radius-sm)","borderRadius":"var(--lia-bs-border-radius)","borderRadiusLg":"var(--lia-bs-border-radius-lg)","formTextMarginTop":"4px","textAreaBorderRadius":"var(--lia-bs-border-radius)","activeFillColor":"var(--lia-bs-primary)","__typename":"InputThemeSettings"},"loading":{"dotDarkColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.2)","dotLightColor":"hsla(var(--lia-bs-white-h), var(--lia-bs-white-s), var(--lia-bs-white-l), 0.5)","barDarkColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.06)","barLightColor":"hsla(var(--lia-bs-white-h), var(--lia-bs-white-s), var(--lia-bs-white-l), 0.4)","__typename":"LoadingThemeSettings"},"link":{"color":"var(--lia-bs-primary)","hoverColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) - 10%))","decoration":"none","hoverDecoration":"underline","__typename":"LinkThemeSettings"},"listGroup":{"itemPaddingY":"15px","itemPaddingX":"15px","borderColor":"var(--lia-bs-gray-300)","__typename":"ListGroupThemeSettings"},"modal":{"contentTextColor":"var(--lia-bs-body-color)","contentBg":"var(--lia-bs-white)","backgroundBg":"var(--lia-bs-black)","smSize":"440px","mdSize":"760px","lgSize":"1080px","backdropOpacity":0.3,"contentBoxShadowXs":"var(--lia-bs-box-shadow-sm)","contentBoxShadow":"var(--lia-bs-box-shadow)","headerFontWeight":"700","__typename":"ModalThemeSettings"},"navbar":{"position":"FIXED","background":{"attachment":null,"clip":null,"color":"var(--lia-bs-white)","imageAssetName":null,"imageLastModified":"0","origin":null,"position":"CENTER_CENTER","repeat":"NO_REPEAT","size":"COVER","__typename":"BackgroundProps"},"backgroundOpacity":0.8,"paddingTop":"15px","paddingBottom":"15px","borderBottom":"1px solid var(--lia-bs-border-color)","boxShadow":"var(--lia-bs-box-shadow-sm)","brandMarginRight":"30px","brandMarginRightSm":"10px","brandLogoHeight":"30px","linkGap":"10px","linkJustifyContent":"flex-start","linkPaddingY":"5px","linkPaddingX":"10px","linkDropdownPaddingY":"9px","linkDropdownPaddingX":"var(--lia-nav-link-px)","linkColor":"var(--lia-bs-body-color)","linkHoverColor":"var(--lia-bs-primary)","linkFontSize":"var(--lia-bs-font-size-sm)","linkFontStyle":"NORMAL","linkFontWeight":"400","linkTextTransform":"NONE","linkLetterSpacing":"normal","linkBorderRadius":"var(--lia-bs-border-radius-sm)","linkBgColor":"transparent","linkBgHoverColor":"transparent","linkBorder":"none","linkBorderHover":"none","linkBoxShadow":"none","linkBoxShadowHover":"none","linkTextBorderBottom":"none","linkTextBorderBottomHover":"none","dropdownPaddingTop":"10px","dropdownPaddingBottom":"15px","dropdownPaddingX":"10px","dropdownMenuOffset":"2px","dropdownDividerMarginTop":"10px","dropdownDividerMarginBottom":"10px","dropdownBorderColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","controllerBgHoverColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.1)","controllerIconColor":"var(--lia-bs-body-color)","controllerIconHoverColor":"var(--lia-bs-body-color)","controllerTextColor":"var(--lia-nav-controller-icon-color)","controllerTextHoverColor":"var(--lia-nav-controller-icon-hover-color)","controllerHighlightColor":"hsla(30, 100%, 50%)","controllerHighlightTextColor":"var(--lia-yiq-light)","controllerBorderRadius":"var(--lia-border-radius-50)","hamburgerColor":"var(--lia-nav-controller-icon-color)","hamburgerHoverColor":"var(--lia-nav-controller-icon-color)","hamburgerBgColor":"transparent","hamburgerBgHoverColor":"transparent","hamburgerBorder":"none","hamburgerBorderHover":"none","collapseMenuMarginLeft":"20px","collapseMenuDividerBg":"var(--lia-nav-link-color)","collapseMenuDividerOpacity":0.16,"__typename":"NavbarThemeSettings"},"pager":{"textColor":"var(--lia-bs-link-color)","textFontWeight":"var(--lia-font-weight-md)","textFontSize":"var(--lia-bs-font-size-sm)","__typename":"PagerThemeSettings"},"panel":{"bgColor":"var(--lia-bs-white)","borderRadius":"var(--lia-bs-border-radius)","borderColor":"var(--lia-bs-border-color)","boxShadow":"none","__typename":"PanelThemeSettings"},"popover":{"arrowHeight":"8px","arrowWidth":"16px","maxWidth":"300px","minWidth":"100px","headerBg":"var(--lia-bs-white)","borderColor":"var(--lia-bs-border-color)","borderRadius":"var(--lia-bs-border-radius)","boxShadow":"0 0.5rem 1rem hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.15)","__typename":"PopoverThemeSettings"},"prism":{"color":"#000000","bgColor":"#f5f2f0","fontFamily":"var(--font-family-monospace)","fontSize":"var(--lia-bs-font-size-base)","fontWeightBold":"var(--lia-bs-font-weight-bold)","fontStyleItalic":"italic","tabSize":2,"highlightColor":"#b3d4fc","commentColor":"#62707e","punctuationColor":"#6f6f6f","namespaceOpacity":"0.7","propColor":"#990055","selectorColor":"#517a00","operatorColor":"#906736","operatorBgColor":"hsla(0, 0%, 100%, 0.5)","keywordColor":"#0076a9","functionColor":"#d3284b","variableColor":"#c14700","__typename":"PrismThemeSettings"},"rte":{"bgColor":"var(--lia-bs-white)","borderRadius":"var(--lia-panel-border-radius)","boxShadow":" var(--lia-panel-box-shadow)","customColor1":"#bfedd2","customColor2":"#fbeeb8","customColor3":"#f8cac6","customColor4":"#eccafa","customColor5":"#c2e0f4","customColor6":"#2dc26b","customColor7":"#f1c40f","customColor8":"#e03e2d","customColor9":"#b96ad9","customColor10":"#3598db","customColor11":"#169179","customColor12":"#e67e23","customColor13":"#ba372a","customColor14":"#843fa1","customColor15":"#236fa1","customColor16":"#ecf0f1","customColor17":"#ced4d9","customColor18":"#95a5a6","customColor19":"#7e8c8d","customColor20":"#34495e","customColor21":"#000000","customColor22":"#ffffff","defaultMessageHeaderMarginTop":"40px","defaultMessageHeaderMarginBottom":"12px","defaultMessageItemMarginTop":"0","defaultMessageItemMarginBottom":"2px","diffAddedColor":"hsla(170, 53%, 51%, 0.4)","diffChangedColor":"hsla(43, 97%, 63%, 0.4)","diffNoneColor":"hsla(0, 0%, 80%, 0.4)","diffRemovedColor":"hsla(9, 74%, 47%, 0.4)","specialMessageHeaderMarginTop":"40px","specialMessageHeaderMarginBottom":"12px","specialMessageItemMarginTop":"0","specialMessageItemMarginBottom":"2px","tableBgColor":"transparent","tableBorderColor":"var(--lia-bs-gray-700)","tableBorderStyle":"solid","tableCellPaddingX":"5px","tableCellPaddingY":"5px","tableTextColor":"var(--lia-bs-body-color)","tableVerticalAlign":"middle","__typename":"RteThemeSettings"},"tags":{"bgColor":"var(--lia-bs-gray-200)","bgHoverColor":"var(--lia-bs-gray-400)","borderRadius":"var(--lia-bs-border-radius-sm)","color":"var(--lia-bs-body-color)","hoverColor":"var(--lia-bs-body-color)","fontWeight":"var(--lia-font-weight-md)","fontSize":"var(--lia-font-size-xxs)","textTransform":"UPPERCASE","letterSpacing":"0.5px","__typename":"TagsThemeSettings"},"toasts":{"borderRadius":"var(--lia-bs-border-radius)","paddingX":"12px","__typename":"ToastsThemeSettings"},"typography":{"fontFamilyBase":"Outfit","fontStyleBase":"NORMAL","fontWeightBase":"400","fontWeightLight":"300","fontWeightNormal":"400","fontWeightMd":"500","fontWeightBold":"700","letterSpacingSm":"normal","letterSpacingXs":"normal","lineHeightBase":"1","fontSizeBase":"17px","fontSizeXxs":"11px","fontSizeXs":"15px","fontSizeSm":"16px","fontSizeLg":"20px","fontSizeXl":"24px","smallFontSize":"14px","customFonts":[{"source":"SERVER","name":"Nunito Regular","styles":[{"style":"NORMAL","weight":"400","__typename":"FontStyleData"}],"assetNames":["NunitoRegular-normal-400.woff2"],"__typename":"CustomFont"},{"source":"SERVER","name":"Nunito Italic","styles":[{"style":"ITALIC","weight":"400","__typename":"FontStyleData"}],"assetNames":["NunitoItalic-italic-400.woff2"],"__typename":"CustomFont"},{"source":"SERVER","name":"Nunito Sans","styles":[{"style":"NORMAL","weight":"400","__typename":"FontStyleData"}],"assetNames":["NunitoSans-normal-400.woff2"],"__typename":"CustomFont"},{"source":"SERVER","name":"Outfit","styles":[{"style":"NORMAL","weight":"400","__typename":"FontStyleData"},{"style":"NORMAL","weight":"700","__typename":"FontStyleData"}],"assetNames":["Outfit-normal-400.woff2","Outfit-normal-700.woff2"],"__typename":"CustomFont"},{"source":"SERVER","name":"Outfit ExtraLight","styles":[{"style":"NORMAL","weight":"100","__typename":"FontStyleData"},{"style":"NORMAL","weight":"600","__typename":"FontStyleData"}],"assetNames":["OutfitExtraLight-normal-100.woff2","OutfitExtraLight-normal-600.woff2"],"__typename":"CustomFont"}],"__typename":"TypographyThemeSettings"},"unstyledListItem":{"marginBottomSm":"5px","marginBottomMd":"10px","marginBottomLg":"15px","marginBottomXl":"20px","marginBottomXxl":"25px","__typename":"UnstyledListItemThemeSettings"},"yiq":{"light":"#ffffff","dark":"#000000","__typename":"YiqThemeSettings"},"colorLightness":{"primaryDark":0.36,"primaryLight":0.74,"primaryLighter":0.89,"primaryLightest":0.95,"infoDark":0.39,"infoLight":0.72,"infoLighter":0.85,"infoLightest":0.93,"successDark":0.24,"successLight":0.62,"successLighter":0.8,"successLightest":0.91,"warningDark":0.39,"warningLight":0.68,"warningLighter":0.84,"warningLightest":0.93,"dangerDark":0.41,"dangerLight":0.72,"dangerLighter":0.89,"dangerLightest":0.95,"__typename":"ColorLightnessThemeSettings"},"localOverride":false,"__typename":"Theme"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/common/Loading/LoadingDot-1759225536345":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/common/Loading/LoadingDot-1759225536345","value":{"title":"Loading..."},"localOverride":false},"CachedAsset:quilt:netgear.prod:pages/forums/ForumMessagePage:board:home-wifi-routers-general-1759225535000":{"__typename":"CachedAsset","id":"quilt:netgear.prod:pages/forums/ForumMessagePage:board:home-wifi-routers-general-1759225535000","value":{"id":"ForumMessagePage","container":{"id":"Common","headerProps":{"backgroundImageProps":null,"backgroundColor":null,"addComponents":null,"removeComponents":["community.widget.bannerWidget"],"componentOrder":null,"__typename":"QuiltContainerSectionProps"},"headerComponentProps":{"community.widget.breadcrumbWidget":{"disableLastCrumbForDesktop":false}},"footerProps":null,"footerComponentProps":null,"items":[{"id":"message-list","layout":"ONE_COLUMN","bgColor":"transparent","showTitle":false,"showDescription":false,"textPosition":"CENTER","textColor":"var(--lia-bs-body-color)","sectionEditLevel":null,"bgImage":null,"disableSpacing":null,"edgeToEdgeDisplay":null,"fullHeight":null,"showBorder":null,"__typename":"OneColumnQuiltSection","columnMap":{"main":[{"id":"messages.widget.topicWithThreadedReplyListWidget","className":"lia-topic-with-replies","props":{"editLevel":"CONFIGURE"},"__typename":"QuiltComponent"}],"__typename":"OneSectionColumns"}}],"__typename":"QuiltContainer"},"__typename":"Quilt","localOverride":false},"localOverride":false},"CachedAsset:text:en_US-components/common/EmailVerification-1759225536345":{"__typename":"CachedAsset","id":"text:en_US-components/common/EmailVerification-1759225536345","value":{"email.verification.title":"Email Verification Required","email.verification.message.update.email":"To participate in the community, you must first verify your email address. The verification email was sent to {email}. To change your email, visit My Settings.","email.verification.message.resend.email":"To participate in the community, you must first verify your email address. The verification email was sent to {email}. Resend email."},"localOverride":false},"CachedAsset:text:en_US-pages/forums/ForumMessagePage-1759225536345":{"__typename":"CachedAsset","id":"text:en_US-pages/forums/ForumMessagePage-1759225536345","value":{"title":"{contextMessageSubject} | {communityTitle}","errorMissing":"This message cannot be found","name":"Forum Message Page","section.message-list.title":"Forum Discussion","archivedMessageTitle":"This Content Has Been Archived","section.ggPfrX.description":"","section.witfun.title":"","section.Ifupfq.description":"","section.HDsmbT.description":"","section.VzPCrA.title":"Forum Discussion","section.zhfXtQ.description":"","section.section-1744733491922.description":"","section.PcIbEX.title":"","section.oqZKRI.title":"Forum Discussion","section.LldQzr.title":"Forum Discussion","section.sEZyct.description":"","section.PcIbEX.description":"","section.Iolbog.title":"Forum Discussion","section.oPauEA.title":"","section.CzkEIE.title":"","section.lfyQfk.title":"Forum Discussion","section.fsPCXp.title":"Forum Discussion","section.jeVZXZ.title":"Forum Discussion","section.section-1744733491922.title":"","section.HDsmbT.title":"Forum Discussion","section.LldQzr.description":"","section.lfyQfk.description":"","section.mamNog.title":"","section.CdMvCb.title":"","section.sEZyct.title":"","section.CzkEIE.description":"","section.Ifupfq.title":"","section.Iolbog.description":"","section.VzPCrA.description":"","section.oqZKRI.description":"","section.section-1743419781857.description":"","section.jeVZXZ.description":"","section.szTWCQ.description":"","section.mamNog.description":"","section.oPauEA.description":"","section.IdAfoe.description":"","section.mfqezj.title":"Forum Discussion","section.section-1743419781857.title":"","section.witfun.description":"","section.szTWCQ.title":"Forum Discussion","section.fsPCXp.description":"","section.CdMvCb.description":"","section.IdAfoe.title":"","section.message-list.description":"","section.zhfXtQ.title":"","section.mfqezj.description":"","section.ggPfrX.title":"Forum Discussion"},"localOverride":false},"CachedAsset:quiltWrapper:netgear.prod:Common:en-US-1759225535643":{"__typename":"CachedAsset","id":"quiltWrapper:netgear.prod:Common:en-US-1759225535643","value":{"id":"Common","header":{"backgroundImageProps":{"assetName":null,"backgroundSize":"COVER","backgroundRepeat":"NO_REPEAT","backgroundPosition":"CENTER_CENTER","lastModified":null,"__typename":"BackgroundImageProps"},"backgroundColor":"#FFFFFF","items":[{"id":"community.widget.navbarWidget","props":{"showUserName":true,"showRegisterLink":true,"useIconLanguagePicker":true,"showLanguagePicker":true,"useLabelLanguagePicker":true,"style":{"boxShadow":"var(--lia-bs-box-shadow-sm)","linkFontWeight":"700","controllerHighlightColor":"#4099E2","dropdownDividerMarginBottom":"10px","hamburgerBorderHover":"none","linkFontSize":"16px","linkBoxShadowHover":"none","backgroundOpacity":0.79,"controllerBorderRadius":"var(--lia-border-radius-50)","hamburgerBgColor":"transparent","linkTextBorderBottom":"none","hamburgerColor":"var(--lia-nav-controller-icon-color)","brandLogoHeight":"32px","linkLetterSpacing":"normal","linkBgHoverColor":"transparent","collapseMenuDividerOpacity":0.16,"paddingBottom":"15px","dropdownPaddingBottom":"15px","dropdownMenuOffset":"2px","hamburgerBgHoverColor":"transparent","borderBottom":"1px solid var(--lia-bs-border-color)","hamburgerBorder":"none","dropdownPaddingX":"10px","brandMarginRightSm":"10px","linkBoxShadow":"none","linkJustifyContent":"flex-start","linkColor":"#000000","collapseMenuDividerBg":"var(--lia-nav-link-color)","dropdownPaddingTop":"10px","controllerHighlightTextColor":"var(--lia-yiq-dark)","controllerTextColor":"var(--lia-nav-controller-icon-color)","background":{"imageAssetName":"","color":"#FFFFFF","size":"COVER","repeat":"NO_REPEAT","position":"CENTER_CENTER","imageLastModified":""},"linkBorderRadius":"var(--lia-bs-border-radius-sm)","linkHoverColor":"#333333","position":"FIXED","linkBorder":"none","linkTextBorderBottomHover":"0","brandMarginRight":"30px","hamburgerHoverColor":"var(--lia-nav-controller-icon-color)","linkBorderHover":"none","collapseMenuMarginLeft":"20px","linkFontStyle":"NORMAL","linkPaddingX":"10px","controllerTextHoverColor":"var(--lia-nav-controller-icon-hover-color)","paddingTop":"15px","linkPaddingY":"5px","linkTextTransform":"NONE","dropdownBorderColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","controllerBgHoverColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.1)","linkDropdownPaddingX":"var(--lia-nav-link-px)","linkBgColor":"transparent","linkDropdownPaddingY":"9px","controllerIconColor":"var(--lia-bs-body-color)","dropdownDividerMarginTop":"10px","linkGap":"10px","controllerIconHoverColor":"var(--lia-bs-body-color)"},"links":{"sideLinks":[],"mainLinks":[{"children":[{"linkType":"INTERNAL","id":"migrated-link-1","params":{"categoryId":"en-netgear-my-community"},"routeName":"CategoryPage"},{"linkType":"INTERNAL","id":"Common-home-networking-link","params":{"categoryId":"home-networking"},"routeName":"CategoryPage"},{"linkType":"INTERNAL","id":"Common-en-home-mobile-solutions-link","params":{"categoryId":"en-home-mobile-solutions"},"routeName":"CategoryPage"},{"linkType":"INTERNAL","id":"migrated-link-3","params":{"categoryId":"business-solutions"},"routeName":"CategoryPage"},{"linkType":"EXTERNAL","id":"migrated-link-4","url":"https://www.netgear.com/hub/","target":"BLANK"}],"linkType":"INTERNAL","id":"migrated-link-2","params":{"categoryId":"home-networking"},"routeName":"CategoryPage"},{"children":[{"linkType":"EXTERNAL","id":"migrated-link-10","url":"https://my.netgear.com/products.aspx?option=viewwarranty","target":"BLANK"},{"linkType":"EXTERNAL","id":"Common-external-link","url":"https://my.netgear.com/cases.aspx","target":"BLANK"},{"linkType":"EXTERNAL","id":"Common-external-link-2","url":"https://my.netgear.com/contracts.aspx","target":"BLANK"}],"linkType":"EXTERNAL","id":"Common-external-link-1","url":"https://my.netgear.com/home.aspx","target":"BLANK"},{"children":[{"linkType":"EXTERNAL","id":"migrated-link-12","url":"https://www.netgear.com/support/download/?model=&_ga=2.38375275.974127454.1697786862-475167439.1689166105","target":"BLANK"},{"linkType":"EXTERNAL","id":"migrated-link-9","url":"https://my.netgear.com/support/contact.aspx","target":"BLANK"}],"linkType":"EXTERNAL","id":"migrated-link-11","url":"https://www.netgear.com/support/","target":"BLANK"},{"children":[],"linkType":"EXTERNAL","id":"migrated-link-13","url":"https://www.netgear.com/search/?query=&tabOrder=.%2Findex.html%2Cblogs%2Ckhoros_conversations%2Cknowledge_articles%2Cproducts%2Csupport&facetFilters=%7B%7D&filters=%7B%7D&referrerPageUrl=https%3A%2F%2Fwww.netgear.com%2Fsupport%2F&verticalUrl=knowledge-articles.html","target":"BLANK"},{"children":[{"linkType":"INTERNAL","id":"migrated-link-15","params":{"boardId":"en-home-orbi-app","categoryId":"home-orbi"},"routeName":"ForumBoardPage"},{"linkType":"INTERNAL","id":"migrated-link-16","params":{"boardId":"en-home-networking-apps","categoryId":"home-wifi-routers"},"routeName":"ForumBoardPage"},{"linkType":"INTERNAL","id":"migrated-link-17","params":{"boardId":"en-home-armor","categoryId":"en-home-networking-apps"},"routeName":"ForumBoardPage"},{"linkType":"INTERNAL","id":"migrated-link-18","params":{"boardId":"en-home-smart-parental-controls","categoryId":"en-home-networking-apps"},"routeName":"ForumBoardPage"},{"linkType":"INTERNAL","id":"Common-en-business-insight-network-management-link","params":{"boardId":"en-business-insight-network-management","categoryId":"en-business-solutions-insight"},"routeName":"ForumBoardPage"}],"linkType":"INTERNAL","id":"Common-en-home-networking-apps-link","params":{"categoryId":"en-home-networking-apps"},"routeName":"CategoryPage"}]},"className":"QuiltComponent_lia-component-edit-mode__0nCcm","showSearchIcon":true,"languagePickerStyle":"iconAndLabel"},"__typename":"QuiltComponent"},{"id":"community.widget.breadcrumbWidget","props":{"backgroundColor":"#FFFFFF","linkHighlightColor":"#333333","visualEffects":{"showBottomBorder":true},"backgroundOpacity":100,"linkTextColor":"#333333"},"__typename":"QuiltComponent"},{"id":"community.widget.bannerWidget","props":{"backgroundColor":"transparent","visualEffects":{"showBottomBorder":true},"backgroundImageProps":{"backgroundSize":"COVER","backgroundPosition":"CENTER_CENTER","backgroundRepeat":"NO_REPEAT"},"fontColor":"var(--lia-bs-body-color)"},"__typename":"QuiltComponent"},{"id":"custom.widget.Alert_Banner","props":{"widgetVisibility":"signedInOrAnonymous","useTitle":true,"usePageWidth":true,"backgroundColor":"#1439FF","useBackground":false,"backgroundOpacity":1,"title":"","lazyLoad":false},"__typename":"QuiltComponent"}],"__typename":"QuiltWrapperSection"},"footer":{"backgroundImageProps":{"assetName":null,"backgroundSize":"COVER","backgroundRepeat":"NO_REPEAT","backgroundPosition":"CENTER_CENTER","lastModified":null,"__typename":"BackgroundImageProps"},"backgroundColor":"var(--lia-bs-body-bg)","items":[{"id":"custom.widget.ReactNetgearFooter","props":{"widgetVisibility":"signedInOrAnonymous","useTitle":true,"usePageWidth":true,"backgroundColor":"#FFFFFF","useBackground":false,"backgroundOpacity":1,"title":"","lazyLoad":false},"__typename":"QuiltComponent"}],"__typename":"QuiltWrapperSection"},"__typename":"QuiltWrapper","localOverride":false},"localOverride":false},"CachedAsset:text:en_US-components/common/ActionFeedback-1759225536345":{"__typename":"CachedAsset","id":"text:en_US-components/common/ActionFeedback-1759225536345","value":{"joinedGroupHub.title":"Welcome","joinedGroupHub.message":"You are now a member of this group and are subscribed to updates.","groupHubInviteNotFound.title":"Invitation Not Found","groupHubInviteNotFound.message":"Sorry, we could not find your invitation to the group. The owner may have canceled the invite.","groupHubNotFound.title":"Group Not Found","groupHubNotFound.message":"The grouphub you tried to join does not exist. It may have been deleted.","existingGroupHubMember.title":"Already Joined","existingGroupHubMember.message":"You are already a member of this group.","accountLocked.title":"Account Locked","accountLocked.message":"Your account has been locked due to multiple failed attempts. Try again in {lockoutTime} minutes.","editedGroupHub.title":"Changes Saved","editedGroupHub.message":"Your group has been updated.","leftGroupHub.title":"Goodbye","leftGroupHub.message":"You are no longer a member of this group and will not receive future updates.","deletedGroupHub.title":"Deleted","deletedGroupHub.message":"The group has been deleted.","groupHubCreated.title":"Group Created","groupHubCreated.message":"{groupHubName} is ready to use","accountClosed.title":"Account Closed","accountClosed.message":"The account has been closed and you will now be redirected to the homepage","resetTokenExpired.title":"Reset Password Link has Expired","resetTokenExpired.message":"Try resetting your password again","invalidUrl.title":"Invalid URL","invalidUrl.message":"The URL you're using is not recognized. Verify your URL and try again.","accountClosedForUser.title":"Account Closed","accountClosedForUser.message":"{userName}'s account is closed","inviteTokenInvalid.title":"Invitation Invalid","inviteTokenInvalid.message":"Your invitation to the community has been canceled or expired.","inviteTokenError.title":"Invitation Verification Failed","inviteTokenError.message":"The url you are utilizing is not recognized. Verify your URL and try again","pageNotFound.title":"Access Denied","pageNotFound.message":"You do not have access to this area of the community or it doesn't exist","eventAttending.title":"Responded as Attending","eventAttending.message":"You'll be notified when there's new activity and reminded as the event approaches","eventInterested.title":"Responded as Interested","eventInterested.message":"You'll be notified when there's new activity and reminded as the event approaches","eventNotFound.title":"Event Not Found","eventNotFound.message":"The event you tried to respond to does not exist.","redirectToRelatedPage.title":"Showing Related Content","redirectToRelatedPageForBaseUsers.title":"Showing Related Content","redirectToRelatedPageForBaseUsers.message":"The content you are trying to access is archived","redirectToRelatedPage.message":"The content you are trying to access is archived","relatedUrl.archivalLink.flyoutMessage":"The content you are trying to access is archived View Archived Content"},"localOverride":false},"CachedAsset:component:custom.widget.Alert_Banner-en-us-1759225629039":{"__typename":"CachedAsset","id":"component:custom.widget.Alert_Banner-en-us-1759225629039","value":{"component":{"id":"custom.widget.Alert_Banner","template":{"id":"Alert_Banner","markupLanguage":"HTML","style":null,"texts":{},"defaults":{"config":{"applicablePages":[],"description":"Banner to be used to share alerts including outages and product announcements","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"components":[{"id":"custom.widget.Alert_Banner","form":null,"config":null,"props":[],"__typename":"Component"}],"grouping":"TEXTHTML","__typename":"ComponentTemplate"},"properties":{"config":{"applicablePages":[],"description":"Banner to be used to share alerts including outages and product announcements","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"form":null,"__typename":"Component","localOverride":false},"globalCss":null,"form":null},"localOverride":false},"CachedAsset:component:custom.widget.ReactNetgearFooter-en-us-1759225629039":{"__typename":"CachedAsset","id":"component:custom.widget.ReactNetgearFooter-en-us-1759225629039","value":{"component":{"id":"custom.widget.ReactNetgearFooter","template":{"id":"ReactNetgearFooter","markupLanguage":"REACT","style":null,"texts":{"custom-footer-aboutus-link":"https://www.netgear.com/about/","custom-footer-aboutus-text":"About Us","custom-footer-contactus-link":"https://www.netgear.com/support/contact.aspx","custom-footer-contactus-text":"Contact us","custom-footer-careers-link":"https://www.netgear.com/about/careers/","custom-footer-careers-text":"Careers","custom-footer-security-link":"https://www.netgear.com/security/","custom-footer-security-text":"Security"},"defaults":{"config":{"applicablePages":[],"description":null,"fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"components":[{"id":"custom.widget.ReactNetgearFooter","form":null,"config":null,"props":[],"__typename":"Component"}],"grouping":"CUSTOM","__typename":"ComponentTemplate"},"properties":{"config":{"applicablePages":[],"description":null,"fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"form":null,"__typename":"Component","localOverride":false},"globalCss":null,"form":null},"localOverride":false},"CachedAsset:text:en_US-components/community/Breadcrumb-1759225536345":{"__typename":"CachedAsset","id":"text:en_US-components/community/Breadcrumb-1759225536345","value":{"navLabel":"Breadcrumbs","dropdown":"Additional parent page navigation"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageBanner-1759225536345":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageBanner-1759225536345","value":{"messageMarkedAsSpam":"This post has been marked as spam","messageMarkedAsSpam@board:TKB":"This article has been marked as spam","messageMarkedAsSpam@board:BLOG":"This post has been marked as spam","messageMarkedAsSpam@board:FORUM":"This discussion has been marked as spam","messageMarkedAsSpam@board:OCCASION":"This event has been marked as spam","messageMarkedAsSpam@board:IDEA":"This idea has been marked as spam","manageSpam":"Manage Spam","messageMarkedAsAbuse":"This post has been marked as abuse","messageMarkedAsAbuse@board:TKB":"This article has been marked as abuse","messageMarkedAsAbuse@board:BLOG":"This post has been marked as abuse","messageMarkedAsAbuse@board:FORUM":"This discussion has been marked as abuse","messageMarkedAsAbuse@board:OCCASION":"This event has been marked as abuse","messageMarkedAsAbuse@board:IDEA":"This idea has been marked as abuse","preModCommentAuthorText":"This comment will be published as soon as it is approved","preModCommentModeratorText":"This comment is awaiting moderation","messageMarkedAsOther":"This post has been rejected due to other reasons","messageMarkedAsOther@board:TKB":"This article has been rejected due to other reasons","messageMarkedAsOther@board:BLOG":"This post has been rejected due to other reasons","messageMarkedAsOther@board:FORUM":"This discussion has been rejected due to other reasons","messageMarkedAsOther@board:OCCASION":"This event has been rejected due to other reasons","messageMarkedAsOther@board:IDEA":"This idea has been rejected due to other reasons","messageArchived":"This post was archived on {date}","relatedUrl":"View Related Content","relatedContentText":"Showing related content","archivedContentLink":"View Archived Content"},"localOverride":false},"Category:category:business-solutions":{"__typename":"Category","id":"category:business-solutions","categoryPolicies":{"__typename":"CategoryPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Category:category:en-netgear-my-community":{"__typename":"Category","id":"category:en-netgear-my-community","categoryPolicies":{"__typename":"CategoryPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Forum:board:en-home-networking-apps":{"__typename":"Forum","id":"board:en-home-networking-apps","forumPolicies":{"__typename":"ForumPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Category:category:en-home-networking-apps":{"__typename":"Category","id":"category:en-home-networking-apps","categoryPolicies":{"__typename":"CategoryPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Forum:board:en-home-armor":{"__typename":"Forum","id":"board:en-home-armor","forumPolicies":{"__typename":"ForumPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Forum:board:en-home-orbi-app":{"__typename":"Forum","id":"board:en-home-orbi-app","forumPolicies":{"__typename":"ForumPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Forum:board:en-business-insight-network-management":{"__typename":"Forum","id":"board:en-business-insight-network-management","forumPolicies":{"__typename":"ForumPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Forum:board:en-home-smart-parental-controls":{"__typename":"Forum","id":"board:en-home-smart-parental-controls","forumPolicies":{"__typename":"ForumPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Category:category:en-home-mobile-solutions":{"__typename":"Category","id":"category:en-home-mobile-solutions","categoryPolicies":{"__typename":"CategoryPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"CachedAsset:text:en_US-components/community/Navbar-1759225536345":{"__typename":"CachedAsset","id":"text:en_US-components/community/Navbar-1759225536345","value":{"community":"Community Home","inbox":"Inbox","manageContent":"Manage Content","tos":"Terms of Service","forgotPassword":"Forgot Password","themeEditor":"Theme Editor","edit":"Edit Navigation Bar","skipContent":"Skip to content","Common_GxOGBp-italian-link":"COMUNITÀ","Common_StQtwX-external-link-7":"Unterstützung nach Produkt","Common_StQtwX-external-link-6":"Downloads","Common_StQtwX-external-link-5":" UNTERSTÜTZUNG","Common_GxOGBp-cable-modems-routers-link":"Modem DSL & Router","Common-business-solutions-link":"NETGEAR For Business","Common_StQtwX-de-netgear-my-community-link":"Meine Gemeinschaft","Common_StQtwX_SXNPsj-wifi-7-link":"Common_SXNPsj-wifi-7-link","Common-external-link-6":"NETGEAR Blog","Common-external-link-5":"Support by product","Common-external-link-4":"Warranty Information","Common-external-link-3":"SEARCH KNOWLEDGE BASE","Common_GxOGBp-external-link-3":" I miei casi","Common_StQtwX-external-link-4":"WISSENSBASIS","Common-en-home-orbi-be-link-1":"Orbi WiFi 7 (BE) Mesh Systems","Common_StQtwX-external-link-3":"Meine Fälle","Common_GxOGBp-external-link-4":"Supporto per prodotto","Common_GxOGBp-external-link":" IL MIO NETGEAR","Common_StQtwX-external-link-2":"Meine Abonnements","Common_GxOGBp-external-link-5":"SUPPORTO","Common_StQtwX-external-link-1":"Meine registrierten Produkte","Common_GxOGBp-external-link-6":"Informazioni sulla garanzia","Common_GxOGBp-external-link-7":"Download","Common_GxOGBp-external-link-8":"BASE DI CONOSCENZA","Common-home-networking-link":"Home Solutions","Common_StQtwX-de-heimnetzwerk-link":"Home-Lösungen","Common_WNjGdS_GxOGBp-it-home-mobile-solutions-link":"Redes de Negocio","Common_GxOGBp-external-link-1":" I miei prodotti registrati","Common_GxOGBp-3":"SUPPORTO","Common_GxOGBp-2":" LA COMUNITÀ","Common_GxOGBp-external-link-2":" I miei abbonamenti","Common-external-link-2":"My Contracts","Common-external-link-1":"MY NETGEAR","Common_GxOGBp-it-home-mobile-solutions-link":"Soluzioni mobili","Common_WNjGdS_GxOGBp-1":" MI NETGEAR","Common_WNjGdS_GxOGBp-0":"DESCARGAS","Common_WNjGdS_GxOGBp-3":"APOYO","Common_WNjGdS_GxOGBp-2":"COMUNIDAD","Common_GxOGBp-1":" IL MIO NETGEAR","Common_SXNPsj-external-link":"MON NETGEAR","Common_GxOGBp-0":" SCARICA","Common_SXNPsj-wifi-7-link":"Communauté","Common_StQtwX-de-business-losungen-link":"Business Lösungen","Common-mobile-wifi-link-1":"Mobile WiFi","Common_StQtwX-de-home-mobile-wifi-link":"Mobile Lösungen","Common-external-link":"My Cases","Common_SXNPsj-wifi-7-routers-link":"Nighthawk WiFi 7 Routers","Common-en-home-orbi-app-link":"Orbi App","migrated-link-18":"NETGEAR Smart Parental Controls","Common-en-home-orbi-be-link":"Orbi WiFi 7 (BE) Mesh Systems","migrated-link-16":"Nighthawk App","migrated-link-17":"NETGEAR Armor","migrated-link-14":"Armor & Parental Controls","migrated-link-15":"Orbi App","migrated-link-12":"Firmware Downloads","migrated-link-13":"KNOWLEDGE BASE","Common-en-home-netgear-armor-link":"NETGEAR Armor, powered by Bitdefender","Common-en-home-networking-apps-link":"NETGEAR APPS","Common_WNjGdS_GxOGBp-external-link":"Registro de mi producto","Common_WNjGdS_GxOGBp-wifi-7-routers-link":"Soluzioni Business","Common_GxOGBp-it-business-soluzioni-link":"Soluzioni Business","migrated-link-10":"My Registered Products","Common_SXNPsj-fr-entreprises-solutions-link":"Solutions Business","migrated-link-11":"SUPPORT","Common_SXNPsj-external-link-2":"My Cases","Common_SXNPsj-external-link-1":"Mes produits enregistrés","Common-home-wifi-link":"Home WiFi","Common_GxOGBp-wifi-7-link":"Rete domestica","Common-en-home-smart-parental-controls-link":"NETGEAR Smart Home Parental Controls","migrated-link-9":"Contact Us","Common_GxOGBp-de-netgear-my-community-link":"Meine Gemeinschaft","migrated-link-7":"Common-external-link-1","migrated-link-8":"Common-external-link-2","Common_StQtwX-external-link":"MEIN NETGEAR","migrated-link-1":"My Community","migrated-link-2":"COMMUNITY","migrated-link-0":"Firmware Downloads","migrated-link-5":"migrated-link-1","migrated-link-6":"Common-external-link","migrated-link-3":"Business Solutions","migrated-link-4":"NETGEAR Blog","Common_GxOGBp-wifi-7-routers-link":"Soluzioni Business","Common_SXNPsj-fr-domestique-reseau-link":"Solutions Pour La Maison","Common_WNjGdS_GxOGBp-wifi-7-link":"Redes de Hogar","Common_SXNPsj-cable-modems-routers-link":"Modems and Modem Gateways","Common_SXNPsj-fr-home-mobile-solutions-link":"Solutions Mobiles","Common_LXGzNf_ZDApqi_SXNPsj-wifi-7-link":"Common_SXNPsj-wifi-7-link","Common_StQtwX_SXNPsj-2":" GEMEINSCHAFT","Common_SXNPsj-3":"SUPPORT","Common-en-home-networking-apps-link-1":"Nighthawk App","Common_SXNPsj-1":"MY NETGEAR","Common_SXNPsj-bienvenue-link":"Ma Communauté","Common_SXNPsj-2":"NETGEAR Forum","Common-cable-modems-routers-link":"Modems and Modem Gateways","Common_WNjGdS_GxOGBp-external-link-3":"BASE DE CONOCIMIENTOS","Common_WNjGdS_GxOGBp-external-link-2":" Mis Casos","Common_WNjGdS_GxOGBp-external-link-1":"Mis Suscripciones","Common-en-netgear-my-community-link":"My Community","Common-digital-canvas-link":"Digital Canvas","Common-wifi-7-routers-link":"Nighthawk WiFi 7 Routers","Common-en-business-insight-network-management-link":"Insight","Common_GxOGBp-it-home-networking-link":"Soluzioni per la casa","Common-wifi-7-link":"Orbi WiFi 7 Mesh Systems","Common-wired-networking-link":"Wired Networking for Home","Common_LXGzNf_ZDApqi_SXNPsj-2":"NETGEAR Forum","Common-mobile-wifi-link":"Mobile WiFi","Common-en-home-mobile-solutions-link":"Mobile Solutions"},"localOverride":false},"CachedAsset:text:en_US-components/community/NavbarHamburgerDropdown-1759225536345":{"__typename":"CachedAsset","id":"text:en_US-components/community/NavbarHamburgerDropdown-1759225536345","value":{"hamburgerLabel":"Side Menu"},"localOverride":false},"CachedAsset:text:en_US-components/community/BrandLogo-1759225536345":{"__typename":"CachedAsset","id":"text:en_US-components/community/BrandLogo-1759225536345","value":{"logoAlt":"Khoros","themeLogoAlt":"Brand Logo"},"localOverride":false},"CachedAsset:text:en_US-components/community/NavbarTextLinks-1759225536345":{"__typename":"CachedAsset","id":"text:en_US-components/community/NavbarTextLinks-1759225536345","value":{"more":"More"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/languages/UseLanguageText-1759225536345":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/languages/UseLanguageText-1759225536345","value":{"language.browserLanguage.label":"Browser Default","language.ar-AE.label":"Arabic","language.bg-BG.label":"Bulgarian","language.ca-AD.label":"Catalan","language.cs-CZ.label":"Czech","language.da-DK.label":"Danish","language.de-DE.label":"German","language.el-GR.label":"Greek","language.en-GB.label":"English (UK)","language.en-US.label":"English (US)","language.es-ES.label":"Spanish","language.es-MX.label":"Spanish (Mexican)","language.et-EE.label":"Estonian","language.fa-IR.label":"Persian (Farsi)","language.fi-FI.label":"Finnish","language.fr-FR.label":"French","language.he-IL.label":"Hebrew (modern)","language.hr-HR.label":"Croatian","language.hu-HU.label":"Hungarian","language.in-ID.label":"Indonesian","language.it-IT.label":"Italian","language.ja-JP.label":"Japanese","language.ko-KR.label":"Korean","language.lt-LT.label":"Lithuanian","language.lv-LV.label":"Latvian","language.ms-MY.label":"Malay","language.nl-NL.label":"Dutch","language.no-NO.label":"Norwegian","language.pl-PL.label":"Polish","language.pt-BR.label":"Portuguese (Brazilian)","language.pt-PT.label":"Portuguese","language.ro-RO.label":"Romanian","language.ru-RU.label":"Russian","language.sk-SK.label":"Slovak","language.sq-AL.label":"Albanian","language.sv-SE.label":"Swedish","language.th-TH.label":"Thai","language.tr-TR.label":"Turkish","language.uk-UA.label":"Ukrainian","language.vi-VN.label":"Vietnamese","language.zh-CN.label":"Chinese (Simplified)","language.zh-TW.label":"Chinese (Traditional)","timezone.fieldLabel.label":"Time Zone","timezone.delimiter.label":"------------------------------","timezone.Etc-GMT+12.label":"GMT -12:00 Dateline","timezone.Pacific-Samoa.label":"GMT -11:00 Samoa","timezone.US-Hawaii.label":"GMT -10:00 U.S. Hawaiian Time","timezone.US-Aleutian.label":"GMT -10:00 Aleutian Islands","timezone.Pacific-Marquesas.label":"GMT -09:30 Marquesas","timezone.Pacific-Gambier.label":"GMT -09:00 Gambier Islands","timezone.US-Alaska.label":"GMT -09:00 U.S. Alaska Time","timezone.US-Pacific.label":"GMT -08:00 U.S. Pacific Time","timezone.Pacific-Pitcairn.label":"GMT -08:00 Pitcairn Islands","timezone.US-Mountain.label":"GMT -07:00 U.S. Mountain Time","timezone.US-Arizona.label":"GMT -07:00 U.S. Mountain Time (Arizona)","timezone.US-Central.label":"GMT -06:00 U.S. Central Time","timezone.Mexico-General.label":"GMT -06:00 Mexico","timezone.America-Costa_Rica.label":"GMT -06:00 Costa Rica","timezone.US-Eastern.label":"GMT -05:00 U.S. Eastern Time","timezone.America-Bogota.label":"GMT -05:00 Colombia, Peru, South America","timezone.Canada-Atlantic.label":"GMT -04:00 Atlantic Time","timezone.America-Puerto_Rico.label":"GMT -04:00 Puerto Rico","timezone.Canada-Newfoundland.label":"GMT -03:30 Newfoundland, Canada","timezone.America-Buenos_Aires.label":"GMT -03:00 Argentina","timezone.Brazil-East.label":"GMT -03:00 Brazil","timezone.Atlantic-South_Georgia.label":"GMT -02:00 Mid-Atlantic","timezone.Atlantic-Cape_Verde.label":"GMT -01:00 Cape Verde","timezone.Atlantic-Azores.label":"GMT -01:00 Azores","timezone.Europe-London.label":"GMT ------ U.K.","timezone.Iceland.label":"GMT ------ Iceland","timezone.Europe-Madrid.label":"GMT +01:00 Spain","timezone.Africa-Algiers.label":"GMT +01:00 Algiers, Africa","timezone.Europe-Amsterdam.label":"GMT +01:00 Central Europe","timezone.Europe-Athens.label":"GMT +02:00 Eastern Europe","timezone.Africa-Tripoli.label":"GMT +02:00 Tripoli, Africa","timezone.Egypt.label":"GMT +02:00 Egypt","timezone.Israel.label":"GMT +02:00 Israel","timezone.Asia-Riyadh.label":"GMT +03:00 Saudi Arabia","timezone.Iran.label":"GMT +03:30 Iran","timezone.Europe-Moscow.label":"GMT +03:00 Russia","timezone.Europe-Samara.label":"GMT +04:00 Samara, Europe","timezone.Asia-Dubai.label":"GMT +04:00 Arabian","timezone.Asia-Kabul.label":"GMT +04:30 Afghanistan","timezone.Asia-Karachi.label":"GMT +05:00 Pakistan, West Asia","timezone.Asia-Yekaterinburg.label":"GMT +05:00 Yekaterinburg, Asia","timezone.Asia-Calcutta.label":"GMT +05:30 India","timezone.Asia-Thimphu.label":"GMT +06:00 Bangladesh, Central Asia","timezone.Asia-Novosibirsk.label":"GMT +06:00 Novosibirsk, Asia","timezone.Asia-Rangoon.label":"GMT +06:30 Burma","timezone.Asia-Bangkok.label":"GMT +07:00 Bangkok, Hanoi, Jakarta","timezone.Asia-Krasnoyarsk.label":"GMT +07:00 Krasnoyarsk, Asia","timezone.PRC.label":"GMT +08:00 China","timezone.Singapore.label":"GMT +08:00 Singapore","timezone.Asia-Taipei.label":"GMT +08:00 Taiwan","timezone.Australia-West.label":"GMT +08:00 Australia (WT)","timezone.Asia-Irkutsk.label":"GMT +08:00 Irkutsk, Asia","timezone.Japan.label":"GMT +09:00 Japan","timezone.Asia-Seoul.label":"GMT +09:00 Korea","timezone.Asia-Yakutsk.label":"GMT +09:00 Yakutsk, Russia","timezone.Australia-North.label":"GMT +09:30 Australia (NT)","timezone.Australia-Adelaide.label":"GMT +09:30 Australia (ST)","timezone.Australia-Sydney.label":"GMT +10:00 Australia (ET)","timezone.Australia-Queensland.label":"GMT +10:00 Australia (Queensland)","timezone.Asia-Magadan.label":"GMT +10:00 Magadan, Asia","timezone.Australia-Lord_Howe.label":"GMT +10:30 Australia (Lord Howe)","timezone.Pacific-Guadalcanal.label":"GMT +11:00 Central Pacific","timezone.Pacific-Norfolk.label":"GMT +11:30 Norfolk Islands","timezone.Pacific-Auckland.label":"GMT +12:00 New Zealand","timezone.Pacific-Fiji.label":"GMT +12:00 Fiji","timezone.Antarctica-South_Pole.label":"GMT +12:00 South Pole, Antarctica"},"localOverride":false},"CachedAsset:text:en_US-components/languages/LanguagePicker-1759225536345":{"__typename":"CachedAsset","id":"text:en_US-components/languages/LanguagePicker-1759225536345","value":{"dropdown.title":"Language selector","selected.language":"Currently selected language","toast.successMessage":"Go to the {newLanguage} community Switch back to {oldLanguage}","toast.successTitle":"Language Changed to {language}","toast.failureTitle":"Error - Action Failed","toast.failureMessage":"An unidentified problem occurred during the action you took. Please try again later."},"localOverride":false},"CachedAsset:text:en_US-components/search/SpotlightSearchIcon-1759225536345":{"__typename":"CachedAsset","id":"text:en_US-components/search/SpotlightSearchIcon-1759225536345","value":{"search":"Search"},"localOverride":false},"CachedAsset:text:en_US-components/authentication/AuthenticationLink-1759225536345":{"__typename":"CachedAsset","id":"text:en_US-components/authentication/AuthenticationLink-1759225536345","value":{"title.login":"Sign In","title.registration":"Register","title.forgotPassword":"Forgot Password","title.multiAuthLogin":"Sign In"},"localOverride":false},"CachedAsset:text:en_US-components/nodes/NodeLink-1759225536345":{"__typename":"CachedAsset","id":"text:en_US-components/nodes/NodeLink-1759225536345","value":{"place":"Place {name}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageView/MessageViewStandard-1759225536345":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageView/MessageViewStandard-1759225536345","value":{"anonymous":"Anonymous","author":"{messageAuthorLogin}","authorBy":"{messageAuthorLogin}","board":"{messageBoardTitle}","replyToUser":" to {parentAuthor}","showMoreReplies":"Show More","replyText":"Reply","repliesText":"Replies","markedAsSolved":"Marked as Solution","messageStatus":"Status: ","statusChanged":"Status changed: {previousStatus} to {currentStatus}","statusAdded":"Status added: {status}","statusRemoved":"Status removed: {status}","labelExpand":"expand replies","labelCollapse":"collapse replies","unhelpfulReason.reason1":"Content is outdated","unhelpfulReason.reason2":"Article is missing information","unhelpfulReason.reason3":"Content is for a different Product","unhelpfulReason.reason4":"Doesn't match what I was searching for"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageDeepLink-1759225536345":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageDeepLink-1759225536345","value":{"viewFullDiscussion@board:FORUM":"View Full Discussion ({repliesCount} Replies)","viewFullDiscussion@board:BLOG":"View Full Discussion ({repliesCount} Comments)","viewFullDiscussion@board:TKB":"View Full Discussion ({repliesCount} Comments)","viewFullDiscussion@board:IDEA":"View Full Discussion ({repliesCount} Comments)","viewFullDiscussion@board:OCCASION":"View Full Discussion ({repliesCount} Comments)","showParents@board:FORUM":"Show Parent Replies","showParents@board:BLOG":"Show Parent Comments","showParents@board:TKB":"Show Parent Comments","showParents@board:IDEA":"Show Parent Comments","showParents@board:OCCASION":"Show Parent Comments"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageReplyCallToAction-1759225536345":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageReplyCallToAction-1759225536345","value":{"leaveReply":"Leave a reply...","leaveReply@board:BLOG@message:root":"Leave a comment...","leaveReply@board:TKB@message:root":"Leave a comment...","leaveReply@board:IDEA@message:root":"Leave a comment...","leaveReply@board:OCCASION@message:root":"Leave a comment...","repliesTurnedOff.FORUM":"Replies are turned off for this topic","repliesTurnedOff.BLOG":"Comments are turned off for this topic","repliesTurnedOff.TKB":"Comments are turned off for this topic","repliesTurnedOff.IDEA":"Comments are turned off for this topic","repliesTurnedOff.OCCASION":"Comments are turned off for this topic","infoText":"Stop poking me!"},"localOverride":false},"Category:category:Italian":{"__typename":"Category","id":"category:Italian","displayId":"Italian"},"Category:category:nederlands-dutch":{"__typename":"Category","id":"category:nederlands-dutch","displayId":"nederlands-dutch"},"Category:category:German":{"__typename":"Category","id":"category:German","displayId":"German"},"Category:category:Spanish":{"__typename":"Category","id":"category:Spanish","displayId":"Spanish"},"Category:category:French":{"__typename":"Category","id":"category:French","displayId":"French"},"Category:category:Chinese":{"__typename":"Category","id":"category:Chinese","displayId":"Chinese"},"Category:category:Japanese":{"__typename":"Category","id":"category:Japanese","displayId":"Japanese"},"QueryVariables:MessageSolutions":{"__typename":"QueryVariables","id":"MessageSolutions","value":{"first":10,"constraints":{"topicId":{"eq":"message:427505"},"solution":{"eq":true}},"sorts":{"postTime":{"direction":"ASC"}},"useAvatar":true,"useAuthorLogin":true,"useAuthorRank":false,"useBody":true,"useKudosCount":false,"useTimeToRead":false,"useMedia":true,"useRepliesCount":false,"useSearchSnippet":false,"useAcceptedSolutionButton":true,"useSolvedBadge":false,"useAttachments":true,"useTags":false,"useUserHoverCard":false,"useNodeHoverCard":false,"usePreviewSubjectModal":false,"useMessageStatus":false}},"ROOT_MUTATION":{"__typename":"Mutation"},"CachedAsset:text:en_US-components/community/NavbarDropdownToggle-1759225536345":{"__typename":"CachedAsset","id":"text:en_US-components/community/NavbarDropdownToggle-1759225536345","value":{"ariaLabelClosed":"Press the down arrow to open the menu"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/common/QueryHandler-1759225536345":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/common/QueryHandler-1759225536345","value":{"title":"Query Handler"},"localOverride":false},"CachedAsset:text:en_US-components/messages/EscalatedMessageBanner-1759225536345":{"__typename":"CachedAsset","id":"text:en_US-components/messages/EscalatedMessageBanner-1759225536345","value":{"escalationMessage":"Escalated to Salesforce by {username} on {date}","viewDetails":"View Details","modalTitle":"Case Details","escalatedBy":"Escalated by: ","escalatedOn":"Escalated on: ","caseNumber":"Case Number: ","status":"Status: ","lastUpdateDate":"Last Update: ","automaticEscalation":"automatic escalation","anonymous":"Anonymous"},"localOverride":false},"CachedAsset:text:en_US-components/users/UserLink-1759225536345":{"__typename":"CachedAsset","id":"text:en_US-components/users/UserLink-1759225536345","value":{"authorName":"View Profile: {author}","anonymous":"Anonymous"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/users/UserRank-1759225536345":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/users/UserRank-1759225536345","value":{"rankName":"{rankName}","userRank":"Author rank {rankName}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageTime-1759225536345":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageTime-1759225536345","value":{"postTime":"Published: {time}","lastPublishTime":"Last Update: {time}","conversation.lastPostingActivityTime":"Last posting activity time: {time}","conversation.lastPostTime":"Last post time: {time}","moderationData.rejectTime":"Rejected time: {time}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageSolvedBadge-1759225536345":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageSolvedBadge-1759225536345","value":{"solved":"Solved"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageSubject-1759225536345":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageSubject-1759225536345","value":{"noSubject":"(no subject)"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageBody-1759225536345":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageBody-1759225536345","value":{"showMessageBody":"Show More","mentionsErrorTitle":"{mentionsType, select, board {Board} user {User} message {Message} other {}} No Longer Available","mentionsErrorMessage":"The {mentionsType} you are trying to view has been removed from the community.","videoProcessing":"Video is being processed. Please try again in a few minutes.","bannerTitle":"Video provider requires cookies to play the video. Accept to continue or {url} it directly on the provider's site.","buttonTitle":"Accept","urlText":"watch"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageCustomFields-1759225536345":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageCustomFields-1759225536345","value":{"CustomField.default.label":"Value of {name}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageReplyButton-1759225536345":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageReplyButton-1759225536345","value":{"repliesCount":"{count}","title":"Reply","title@board:BLOG@message:root":"Comment","title@board:TKB@message:root":"Comment","title@board:IDEA@message:root":"Comment","title@board:OCCASION@message:root":"Comment"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageSolutionList-1759225536345":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageSolutionList-1759225536345","value":{"emptyDescription":"No has been message solutions yet"},"localOverride":false},"User:user:3034":{"__typename":"User","id":"user:3034","uid":3034,"login":"ElaineM","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2015-07-08T10:14:54.091-07:00"},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.netgear.com/t5/s/ejquo23388/images/dS0zMDM0LTE5ODFpQUZFN0QxODE2QTg0RjVGQQ"},"entityType":"USER","eventPath":"community:ejquo23388/user:3034"},"User:user:313090":{"__typename":"User","id":"user:313090","entityType":"USER","eventPath":"community:ejquo23388/user:313090","deleted":false,"uid":313090,"login":"hksteve","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2016-03-19T17:33:29.752-07:00"}},"ForumReplyMessage:message:1063801":{"__typename":"ForumReplyMessage","uid":1063801,"id":"message:1063801","entityType":"FORUM_REPLY","eventPath":"category:home-wifi-routers/category:home-networking/category:English/community:ejquo23388board:home-wifi-routers-general/message:427505/message:1063801","revisionNum":1,"author":{"__ref":"User:user:313090"},"readOnly":false},"ModerationData:moderation_data:1064733":{"__typename":"ModerationData","id":"moderation_data:1064733","status":"APPROVED","rejectReason":null},"AcceptedSolutionMessage:message:1064733":{"__typename":"AcceptedSolutionMessage","author":{"__ref":"User:user:3034"},"id":"message:1064733","entityType":"FORUM_REPLY","eventPath":"category:home-wifi-routers/category:home-networking/category:English/community:ejquo23388board:home-wifi-routers-general/message:427505/message:1064733","revisionNum":1,"uid":1064733,"depth":4,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:home-wifi-routers-general"},"parent":{"__ref":"ForumReplyMessage:message:1063801"},"conversation":{"__ref":"Conversation:conversation:427505"},"subject":"Re: Trek PR2000 DHCP-problems, keeps dropping connections, maybe workaround","moderationData":{"__ref":"ModerationData:moderation_data:1064733"},"body":"
\n hksteve I would like to inform you that the fix is now available in our download page.
\n
\n Feel free to update your firmware and provide feedback.
\n
\n
\n
\n Thanks!
","body@stripHtml({\"removeProcessingText\":true,\"removeSpoilerMarkup\":true,\"removeTocMarkup\":true,\"truncateLength\":200})@stringLength":"173","postTime":"2016-03-22T08:50:53.283-07:00","lastPublishTime":"2016-03-22T08:50:53.283-07:00","images":{"__typename":"AssociatedImageConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"attachments":{"__typename":"AttachmentConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"solution":true,"metrics":{"__typename":"MessageMetrics","views":14768},"placeholder":false,"showMoveIndicator":false,"originalMessageForPlaceholder":null,"videos":{"__typename":"VideoConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"isEscalated":null,"customFields":[],"messagePolicies":{"__typename":"MessagePolicies","canReply":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.forums.action.message.reply_to_entity.allow.accessDenied","key":"error.lithium.policies.forums.action.message.reply_to_entity.allow.accessDenied","args":[]}},"canAcceptSolution":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.accepted_solutions.action_allow.message.mark_as_accepted_solution.accessDenied","key":"error.lithium.policies.accepted_solutions.action_allow.message.mark_as_accepted_solution.accessDenied","args":[]}},"canRejectSolution":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.accepted_solutions.action_allow.message.unmark_as_accepted_solution.accessDenied","key":"error.lithium.policies.accepted_solutions.action_allow.message.unmark_as_accepted_solution.accessDenied","args":[]}},"canTag":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.labels.action.labelableentity.set_labels.allow.accessDenied","key":"error.lithium.policies.labels.action.labelableentity.set_labels.allow.accessDenied","args":[]}},"canEdit":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.forums.action_allow.edit_message.accessDenied","key":"error.lithium.policies.forums.action_allow.edit_message.accessDenied","args":[]}},"canKudo":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.kudos.action.entity.give_kudos.allow.accessDenied","key":"error.lithium.policies.kudos.action.entity.give_kudos.allow.accessDenied","args":[]}}}},"User:user:148600":{"__typename":"User","id":"user:148600","uid":148600,"login":"grechlni","deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://community.netgear.com/t5/s/ejquo23388/m_assets/avatars/default/avatar-10.svg?time=0"},"rank":{"__ref":"Rank:rank:42"},"email":"","messagesCount":3,"biography":null,"topicsCount":0,"kudosReceivedCount":0,"kudosGivenCount":0,"kudosWeight":1,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2014-05-14T15:32:09.000-07:00","confirmEmailStatus":null},"followersCount":null,"solutionsCount":0},"ModerationData:moderation_data:427509":{"__typename":"ModerationData","id":"moderation_data:427509","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"Revision:revision:427509_1":{"__typename":"Revision","id":"revision:427509_1","lastEditTime":"2014-05-22T12:55:21.000-07:00"},"QueryVariables:ReplyList:message:427509:1":{"__typename":"QueryVariables","id":"ReplyList:message:427509:1","value":{"id":"message:427509","first":10,"sorts":{"postTime":{"direction":"ASC"}},"repliesFirst":3,"repliesFirstDepthThree":1,"repliesSorts":{"postTime":{"direction":"ASC"}},"useAvatar":true,"useAuthorLogin":true,"useAuthorRank":true,"useBody":true,"useKudosCount":true,"useTimeToRead":false,"useMedia":false,"useReadOnlyIcon":false,"useRepliesCount":true,"useSearchSnippet":false,"useAcceptedSolutionButton":true,"useSolvedBadge":false,"useAttachments":false,"attachmentsFirst":5,"useTags":false,"useNodeAncestors":false,"useUserHoverCard":false,"useNodeHoverCard":false,"useModerationStatus":true,"usePreviewSubjectModal":false,"useMessageStatus":true}},"CachedAsset:text:en_US-components/customComponent/CustomComponent-1759225536345":{"__typename":"CachedAsset","id":"text:en_US-components/customComponent/CustomComponent-1759225536345","value":{"errorMessage":"Error rendering component id: {customComponentId}","bannerTitle":"Video provider requires cookies to play the video. Accept to continue or {url} it directly on the provider's site.","buttonTitle":"Accept","urlText":"watch"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/users/UserAvatar-1759225536345":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/users/UserAvatar-1759225536345","value":{"altText":"{login}'s avatar","altTextGeneric":"User's avatar"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/ranks/UserRankLabel-1759225536345":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/ranks/UserRankLabel-1759225536345","value":{"altTitle":"Icon for {rankName} rank"},"localOverride":false},"CachedAsset:text:en_US-components/common/ExternalLinkWarningModal-1759225536345":{"__typename":"CachedAsset","id":"text:en_US-components/common/ExternalLinkWarningModal-1759225536345","value":{"title":"Leaving the Community","description":"You're about to leave this site and navigate to an external domain. Are you sure you want to continue?","action.submit":"Continue","action.cancel":"Go Back"},"localOverride":false},"CachedAsset:text:en_US-components/messages/AcceptedSolutionButton-1759225536345":{"__typename":"CachedAsset","id":"text:en_US-components/messages/AcceptedSolutionButton-1759225536345","value":{"accept":"Mark as Solution","accepted":"Marked as Solution","errorHeader":"Error!","errorAdd":"There was an error marking as solution.","errorRemove":"There was an error unmarking as solution.","solved":"Solved","topicAlreadySolvedErrorTitle":"Solution Already Exists","topicAlreadySolvedErrorDesc":"Refresh the browser to view the existing solution"},"localOverride":false},"CachedAsset:text:en_US-components/messages/ThreadedReplyList-1759225536345":{"__typename":"CachedAsset","id":"text:en_US-components/messages/ThreadedReplyList-1759225536345","value":{"title":"{count, plural, one{# Reply} other{# Replies}}","title@board:BLOG":"{count, plural, one{# Comment} other{# Comments}}","title@board:TKB":"{count, plural, one{# Comment} other{# Comments}}","title@board:IDEA":"{count, plural, one{# Comment} other{# Comments}}","title@board:OCCASION":"{count, plural, one{# Comment} other{# Comments}}","noRepliesTitle":"No Replies","noRepliesTitle@board:BLOG":"No Comments","noRepliesTitle@board:TKB":"No Comments","noRepliesTitle@board:IDEA":"No Comments","noRepliesTitle@board:OCCASION":"No Comments","noRepliesDescription":"Be the first to reply","noRepliesDescription@board:BLOG":"Be the first to comment","noRepliesDescription@board:TKB":"Be the first to comment","noRepliesDescription@board:IDEA":"Be the first to comment","noRepliesDescription@board:OCCASION":"Be the first to comment","messageReadOnlyAlert:BLOG":"Comments have been turned off for this post","messageReadOnlyAlert:TKB":"Comments have been turned off for this article","messageReadOnlyAlert:IDEA":"Comments have been turned off for this idea","messageReadOnlyAlert:FORUM":"Replies have been turned off for this discussion","messageReadOnlyAlert:OCCASION":"Comments have been turned off for this event"},"localOverride":false}}}},"page":"/forums/ForumMessagePage/ForumMessagePage","query":{"boardId":"home-wifi-routers-general","messageSubject":"trek-pr2000-dhcp-problems-keeps-dropping-connections-maybe-workaround","messageId":"427505","replyId":"427509"},"buildId":"iWB5jxAgv6Dzg8_YScW7W","runtimeConfig":{"buildInformationVisible":false,"logLevelApp":"info","appLogLevelOverrides":"TenancyMiddleware=TRACE,OriginHelper=TRACE","logLevelMetrics":"info","surveysEnabled":true,"openTelemetry":{"clientEnabled":false,"configName":"netgear","serviceVersion":"25.9.0","universe":"prod","collector":"http://localhost:4318","logLevel":"error","routeChangeAllowedTime":"5000","headers":"","enableDiagnostic":"false","maxAttributeValueLength":"4095"},"apolloDevToolsEnabled":false,"quiltLazyLoadThreshold":"3"},"isFallback":false,"isExperimentalCompile":false,"dynamicIds":["components_seo_QAPageSchema","components_community_Navbar_NavbarWidget","components_community_Breadcrumb_BreadcrumbWidget","components_customComponent_CustomComponent","components_messages_TopicWithThreadedReplyListWidget","components_languages_LanguagePicker","components_messages_MessageView_MessageViewStandard","components_external_components_ExternalComponent","components_messages_EscalatedMessageBanner","components_customComponent_CustomComponentContent_HtmlContent","shared_client_components_common_List_UnstyledList","components_messages_MessageView","components_customComponent_CustomComponentContent_CustomComponentScripts"],"appGip":true,"scriptLoader":[]}
