sdbrown's avatar
sdbrown
Tried everything - still dropping internet
I have tried everything to keep my internet up. Here are the symptoms: Internet starts to slow down to a crawl. Wifi devices just can't get anywhere. I do a speedtest and it my speed shows up as abo...
  • sdbrown's avatar
    sdbrown
    Dec 12, 2016
    1. What is the speed that you are getting when connected straight to the modem?
    I'm getting 65 down 4 up
    2. Have you tried doing a factory reset on the router?
    No, everything but this.
    3. Have you tried reflashing the latest firmware for the router?
    I have the latest firmware and have NOT tried to reflash with the same firmware again.
    4. Does the issue affect all your devices (wired and wireless)?
    Yes, it affects wired and weireless.
    5. What is the model number and firmware version of your device?
    Nighthawk X6 R8000 latest firmware - V1.0.3.4_1.1.2
