sdbrown
Dec 11, 2016Aspirant
Tried everything - still dropping internet
I have tried everything to keep my internet up. Here are the symptoms: Internet starts to slow down to a crawl. Wifi devices just can't get anywhere. I do a speedtest and it my speed shows up as abo...
- Dec 12, 2016
1. What is the speed that you are getting when connected straight to the modem?
I'm getting 65 down 4 up
2. Have you tried doing a factory reset on the router?
No, everything but this.
3. Have you tried reflashing the latest firmware for the router?
I have the latest firmware and have NOT tried to reflash with the same firmware again.
4. Does the issue affect all your devices (wired and wireless)?
Yes, it affects wired and weireless.
5. What is the model number and firmware version of your device?
Nighthawk X6 R8000 latest firmware - V1.0.3.4_1.1.2
DexterJB
Dec 12, 2016NETGEAR Moderator
Hi sdbrown,
Dexter
Community Team
sdbrown
Dec 12, 2016Aspirant
- DexterJBDec 13, 2016NETGEAR Moderator
Hi sdbrown,
Thank for responding.
You can try doing a factory reset but if the issue persists, try reflashing the latest firmware then reset and reconfigure the router. Please keep us posted on the results.
Dexter
Community Team
- sdbrownDec 13, 2016Aspirant
Just updated to the latest BETA firmware R8000-V1.0.3.26_1.1.18. Cleared the logs, now I'll see what the internet does after 24 hours. It sure would be handy to have a periodic ping latency and speed test report without having to do it manually so that it shows up in the router log. More Detailed router logs would be nice.
