Eric_5555's avatar
Oct 21, 2015
Trouble connecting Netgear router to Verizon wifi modem
I have the Actiontec wireless router/modem that was supplied to me by Verizon.  There is an input for a coax cable, a WAN, and 4 LAN connections.  The Internet comes in from the wall to the coax port...
  • Eric_5555's avatar
    Oct 22, 2015
    I found the solution.  I had to go into the settings for my original modem and disable the wireless option.  Once I did this, the Netgear was able to figure everything out and connect to the Internet.
