aweissmeister's avatar
Jan 28, 2020
Trouble with Port Forwarding on WNDR4300V2
WNDR4300V2 Firmware V1.0.0.56   I'm looking to connect a particular service that I'm running through a VM on a local FreeNAS box so I can manage it remotely. The service is working internally perfe...
  • antinode's avatar
    Jan 29, 2020
    > [...] I have noticed that my public IP address (71.78.X.X) which I can
    > use various services look up (ping, nmap, google, etc.) is different
    > from the IP address that is listed in the router (170.20.X.X), [...]
       Where "the IP address that is listed in the router" means the IP
    address of the router's WAN/Internet interface (not its LAN interface)?
       "170.b.c.d" or "172.b.c.d"?  (I'd bet on the latter; "170.20.c.d" is
    a real-world address.)  Whatever it really is, plug it into the form at:
          https://whois.arin.net/
       It appears that your ISP may be using carrier-grade NAT:
          https://en.wikipedia.org/wiki/Carrier-grade_NAT
       If so, then your router will not get a public WAN/Internet IP
    address, and so you will not be able to make port forwarding work (from
    the outside world).
       The only solutions I know are: 1) to ask your ISP for a real public
    address (for which they might charge more), or 2) to use a tunneling
    service like the one mentioned in another thread (near the end):
          https://community.netgear.com/t5/x/x/m-p/1748431
       On the bright side, with the possible exception of the "170 v. 172"
    confusion, it's a rare treat around here to read a problem report which
    includes a coherent, detailed problem description instead of a useless
    mess.  It's appreciated.
