brogerso
Nov 28, 2015Tutor
Troubleshooting N750 passphrase change
Hello. I have an N750 wireless router WNDR 4300 model. As a courtesy to a neighbor who was in a bind, I shared my network wifi password. But now I'd like to change my password. I've bee...
- Nov 29, 2015
Do you have a laptop or computer with an Ethernet port? If you do, then connect it to one of the router's LAN ports with an Ethernet cable. Log into the router, change the Wi-Fi password and apply the change. Wait about a minute, then try to connect to the Wi-Fi network with a wireless device.
brogerso
Nov 29, 2015Tutor
Thanks for the reply.
Unfortunately, my network disappeared. And when it reappeared, it would accept neither the new or the old passphrase. The repeated error message said 'connection timeout.' So I reset the router. The factory password works, but I'm back to square 1.
TheEther
Nov 29, 2015Guru
- brogersoNov 29, 2015Tutor
The Ethernet connection made all the difference. Thanks for your patience and help!
