mgfarnum
Oct 11, 2015Aspirant
Trying to Change The Name of the Ethernet Network (Not Connection Name)
After installing the Netgear R6300 Router I changed the name of the WiFi networks (both 2.4 and 5.0) without issue but the default Network name for the Ethernet Connection is Network 5. I have gone t...
DexterJB
Oct 13, 2015NETGEAR Moderator
Hi mgfarnum,
This is not something that you can do through your NETGEAR device since this is how Windows configured their operating system and network naming scheme. You can check this link and see if this is something that you are willing to try.
Dexter
Community Team
mgfarnum
Oct 19, 2015Aspirant
Thank you. Thios solution worked perfectly.
