lozswioklo
Nov 24, 2019Aspirant
Trying to configure D6200 modem router for iinet NBN
Hi , hoping someone can point us in the right direction. Struggling to configure our netgear modem router to work with iinet NBN. Just seems like we have settings we are supposed to set for iinet b...
- Nov 25, 2019
Hi, just wanted to say thanks - Firmware was what was causing us grief, we weren't seeing the new NBN fields in the outdated Netgear Genie. Your message gave me enough of a hint to track down what was wrong.
Anyone else who has a similar issue, ask your Internet Provider for details more than once (as originally they gave us the wrong login info), upgrade the Firmware if you don't see the settings you need to change.
:smileyhappy:
lozswioklo
Nov 25, 2019Aspirant
Hi, yep sorry
Device: Netgear D6200 DSL Modem Router
_ _ _ _ _ _ _
routerlogin.net
Netgear Genie D6200 firmware: v1.1.00.09_1.00.09
Tried genie autowizard a few times, not working. So tried configuring under advanced tab.
_ _ _ _ _ _ _
iinet supplied config instructions:
- WAN interface: VDSL
- WAN type: PPPoE
- VLAN ID: 2
- Encapsulation: PPPoE
- login name : supplied
- password: supplied
- Idle timeout: always on
- IP address: get dynamically
- DNS: get auto from IPS
- NAT: enable
- Router: use default
In network genie I can't seem to find:
- WAN type: PPPoE
- VLAN ID: 2
_ _ _ _ _ _ _
Under advanced home tab, the little status tiles are currently:
Green tick: router information , wireless settings 2.4ghz, wireless settings 5.0ghz
Red cross : Internet Port
Yellow alert: guest wireless settings 2.4ghz, guest wireless settings 5.0ghz
_ _ _ _ _ _ _
X (red cross) internet port
Mac address: filled out
IP address: 0.0.0.0
Active connection: PPPoE
IP subset mask: 0.0.0.0
Domain name server: 0.0.0.0
_ _ _ _ _ _ _
routerlogin.net
_ _ _ _ _ _ _
- WAN type: PPPoE
- VLAN ID: 2
- NAT: enable
- WAN type: PPPoE
- VLAN ID: 2
_ _ _ _ _ _ _
_ _ _ _ _ _ _
IP address: 0.0.0.0
lozswioklo
:smileyhappy:
