tobeetwo
Mar 30, 2021Aspirant
trying to reboot my Nighthawk router from another state
Don't understand the directions to reboot my A7000 remotely. I'm in another state and my wifi is down at home. Comcast shows my modem is working fine. How do you reboot the router remotely. I have th...
michaelkenward
Apr 02, 2021Guru - Experienced User
tobeetwo wrote:
Don't understand the directions to reboot my A7000 remotely. I'm in another state and my wifi is down at home. Comcast shows my modem is working fine. How do you reboot the router remotely. I have the Netgear app, but can't find the router.
The A7000 is a WiFi USB Adapter. It can't do anything to reboot your router.
My guess is that you have picked the wrong device and posted your question in the wrong section of this community.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Look for the model number on the label on the device.
tobeetwo
Apr 02, 2021Aspirant
Oops
meant Router AC 1900
- michaelkenwardApr 02, 2021Guru - Experienced User
tobeetwo wrote:
Oops
Nope.
AC1900 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds. Netgear makes several routers that are AC1900.
- tobeetwoApr 02, 2021Aspirant
Found my manual
Nighthawk AC1750 Smart WiFi Router
Model R6700v3
