verdonv
Mar 31, 2021Aspirant
Trying to reset my router
Hi, I have a Netgear R6120 router, which I just did a factory reset on. When I did that and tried to login to the router, it offered a firmware update which I did. It rebooted and now I am trying...
- Mar 31, 2021
Try logging in use the routers IP address.
verdonv
Thank you. That worked. I was first presented with a message "
Unable to login or create your NETGEAR Account
We are unable to log you in or create your NETGEAR account at this time.You can still proceed with the installation process and try again later."
When I clicked on "Try Again Later" it led to my router's admin screen.
Should I have any concern that the router seems to have been disasociated with it's registration that I did, when I bought it?
Mar 31, 2021Guru - Experienced User
Shouldn't be an issue. If you've already got it registered for support/warranty issues then its already on your account
