katyireland's avatar
katyireland
Trying to update router firmware
Hi, I am trying to update my router firmware, and get as far as #3 in the installation instructions below, but then it asks for a username and password and I don't know what they are? Write down al...
  • michaelkenward's avatar
    Oct 20, 2016
    If you haven't changed it the default password is password
    If that does not work, then someone has set a different password.
    The way to get control back under those circumstances is to do a "factory reset" which will restore the default password.
    Documentation here:  WNDR3800 | Product | Support | NETGEAR
