tylerh13
May 11, 2022Follower
turn off 5g on r6230
Can I turn off the wifi. I don't want the network hidden. I don't want wifi in my house. Thanks
May 12, 2022Guru - Experienced User
There's a wifi on/off button on t he back of the router. You can push and hold it for 2 seconds to shut off wifi.
Otherwise, you can disable the radio if you log in through the browser and go to advanced tab---->advanced setup----->wireless settings.
You can find manuals here:
