timmzhao
Jan 28, 2022Aspirant
"Turn off wireless signal by schedule" feature not working
Hi, my router is N300 Model WNR2020. In this router, there is a "Turn off wireless signal by schedule" feature. But I found this feature is not working. For example, I set up the followin...
michaelkenward
Jan 29, 2022Guru - Experienced User
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
It might also help if you told people what the modem is in front of this router, if there is one. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
This router from 2016 was never one of the most powerful around and is getting a bit long in the tooth and there hasn't been any new firmware since 2019, so don't expect much. But it should still work. Have you ever put it through a factory reset?
timmzhao
Jan 29, 2022Aspirant
Router's data
Hardware Version: WNR2020
Firmware Version: V1.1.0.62_1.0.1
GUI Language Version: V1.1.0.32
I am reluctant to download any so-called latest firmware from Netgear, because many people on this forum claim that Netgear router software is pure garbage and crap, to put it mildly. New firmware is even more garbage-r than old version.
Yes, I put this Netgear router behind the modem that my ISP gave to me. But why does it matter? And I have performed factory reset multiple times. Still no good.
I also own a TP-Link router that also have a turn-off-Wifi-by-schedule feature. It works 100% of the time no matter where/how I set up this router (behind a modem or whatsoever).
- michaelkenwardJan 30, 2022Guru - Experienced User
Because we need to know what that modem is.
Every day people turns up here and say "I put this Netgear router behind the modem". As often as not this "modem" is no such thing. It is modem/router. That's what ISPs "give" to many customers.
I did explain that in my first reply.
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.If you want help, answer the questions people put to you. They are there for a reason.
- timmzhaoJan 30, 2022Aspirant
I consider myself fairly network savvy. I know what I am doing. I even know how to create a network segment using a non-standard subnet mask like 255.255.255.128. Do I need to say more?
I connected the WAN port of the Netgear router to a LAN port in that ISP's Modem/router combo.
I set up the WAN/LAN configuration properly ( LAN address, subnet mask, DHCP data, etc. ) in both units. Netgear router is giving out DHCP IP address in its own sub-segment.
My laptop connects to the Netgear router wirelessly, and it can access Internet without issue.
But this turn-off-Wifi-by-schedule feature just does not work.
Have Netgear programmers/testers ever tested this feature befor shipping out such products? Do they have the courage to stand up and speak the truth?
- Jared2380May 11, 2022AspirantHas there been any resolution to this? The check box is still greyed out
