packrules9
Nov 16, 2021Aspirant
Turning off guest network
After turning off my guest network, none of my other devices could connect to the router. The message on our phones said it couldn't connect because of an "authentication error". I turned the guest...
Nov 16, 2021Guru - Experienced User
I'd factory reset the router and set up from scratch with a web browser. Once it's setup, make sure the Guest Network if OFF and the main wifi network is configured. As a quick test, disable WPA2 on the router and see if the devices connect with open wifi, if so, go in and enable WPA2 and AES.
packrules9
Nov 18, 2021Aspirant
Hi - How does one do a factory reset?
Also - for the "quick test" you mentioned. Did you mean before doing the factory reset? I tried that and nothing changed. Still killed my connections when I turned off Guest.
- cscott1Nov 18, 2021Guide
For a factory reset there should be a small hole in the back of the router use a paperclip or toothpick to preform the reset hold it in for a few seconds until the lights on the router flash then power off the router or unplug it for a minute then plug it back in should be back to factory settingd.
