Greyhoundmom
Jul 19, 2018Tutor
Two of my three wifi networks not showing up
I have three networks set up for my WNDR3700v2 wifi router. They were all working this morning and now two of them aren't. The one that is working is a 5ghz network. The two that suddenly aren't work...
- Jul 21, 2018
Thank you! Those would have been good things to try! I just went out and bought a new router. :)
wcalifas831
Jul 21, 2018Prodigy
Could be failing, You can try and do a hard reset but it will give it its default SSID(wifi name) and password that is located on the bottom label of the router. You'll also have to run the setup again to detect your internet. Besides that, you can try and see if there's a firmware upgrade for your router and maybe that can fix it. If not, it's time for a new router.
Greyhoundmom
Jul 21, 2018Tutor
- wcalifas831Jul 22, 2018Prodigy
your streaming box and samsung camera won't connect to the 5ghz wifi because they only operate on the 2.4ghz band only.
