JanieKL
Feb 08, 2025Aspirant
Two routers; do I need both?
I have two routers: N300 Wireless Router (WNR2000v3) and AC1200 Dual Band WiFi Router (R6120) My son in law had me get the AC1200 because I was working VOIP. The connection has always had issues...
Feb 08, 2025Guru - Experienced User
The R series is a bit newer than the WNR series. Both are of older generation. Try the R series router first and if it's not working well, try a RAX series as these are newer generation routers.
