JanieKL
Feb 08, 2025Aspirant
Two routers; do I need both?
I have two routers: N300 Wireless Router (WNR2000v3) and AC1200 Dual Band WiFi Router (R6120) My son in law had me get the AC1200 because I was working VOIP. The connection has always had issues...
Feb 09, 2025Guru - Experienced User
You should get rid of both those devices and get something half decent.
Both those devices are old 10/100mbps devices without the capability for gigabit.
And both are pretty low performing for wireless specs.
But if they serve your needs, stick with the r6120.
If it was me? You can pickup renewed/used devices that are much newer, higher performing for pretty cheap
- JanieKLFeb 09, 2025Aspirant
What do you recommend?
- FURRYe38Feb 09, 2025Guru - Experienced User
Try a RAX series as these are newer generation routers:
https://www.netgear.com/home/wifi/routers/listing-filter/ax-wifi6-2/
