JanieKL
Feb 08, 2025Aspirant
Two routers; do I need both?
I have two routers: N300 Wireless Router (WNR2000v3) and AC1200 Dual Band WiFi Router (R6120) My son in law had me get the AC1200 because I was working VOIP. The connection has always had issues...
JanieKL
Feb 09, 2025Aspirant
What do you recommend?
Feb 09, 2025Guru - Experienced User
Try a RAX series as these are newer generation routers:
https://www.netgear.com/home/wifi/routers/listing-filter/ax-wifi6-2/
