tom24
Jan 10, 2017Tutor
Two routers on one network netgear setup
Hi, I'd like to ask for some help setting up my Netgear N300 router as a second router, so it will be on the same network already existing. I managed to make the router function, but it showed up as ...
- Jan 13, 2017
Thanks guys for your answers, I'll try to make it work as a AP ;-)
Adewale
Jan 10, 2017Luminary
have you thought of setting up your second router as an Access Point...that way you dont have to maully set anything....just look for the option to put the N300 into AP mode and you should be fine
