tom24
Jan 10, 2017Tutor
Two routers on one network netgear setup
Hi, I'd like to ask for some help setting up my Netgear N300 router as a second router, so it will be on the same network already existing. I managed to make the router function, but it showed up as ...
- Jan 13, 2017
Thanks guys for your answers, I'll try to make it work as a AP ;-)
Jan 10, 2017Guru - Experienced User
Can you tell us more about what you want to accomplish? Do you want better wifi coverage? Or something else.
