tom24
Jan 10, 2017Tutor
Two routers on one network netgear setup
Hi, I'd like to ask for some help setting up my Netgear N300 router as a second router, so it will be on the same network already existing. I managed to make the router function, but it showed up as ...
- Jan 13, 2017
Thanks guys for your answers, I'll try to make it work as a AP ;-)
Jan 11, 2017Guru - Experienced User
Adewale wrote:
your easiest option is to make the Netgear router an Access point...
Yes, that is the proper mode. You don't want the JNR3210 to be routing at all. Making it an AP will extend your main network.
tom24
Jan 13, 2017Tutor
