INFTeamLeader
Sep 17, 2015Aspirant
Unable to access a website on a R6300
Yesterday a website I frequent became unavailable. i get ERR_CONNECTION_TIMED_OUT. It is 69.73.172.48(www.waguns.org). I can tracert to it but not PING it. When I connect directly into my broadband ...
- Sep 18, 2015
Hi INFTeamLeader,
If you are with a cable ISP, you may try performing MAC spoofing and see if it works. You may refer to the link below for the instructions:
http://kb.netgear.com/app/answers/detail/a_id/1086
Dexter
Community Team
DexterJB
Sep 18, 2015NETGEAR Moderator
Hi INFTeamLeader,
Is the tracert command that you have performed through the router? If it is, it does show that it is being routed going out to your ISP but it gets dropped somewhere over the Internet (starting from line 19). Can you try using OpenDNS? You may refer to this link on how to set it up.
Dexter
Community Team
