INFTeamLeader
Sep 17, 2015Aspirant
Unable to access a website on a R6300
Yesterday a website I frequent became unavailable. i get ERR_CONNECTION_TIMED_OUT. It is 69.73.172.48(www.waguns.org). I can tracert to it but not PING it. When I connect directly into my broadband ...
- Sep 18, 2015
Hi INFTeamLeader,
If you are with a cable ISP, you may try performing MAC spoofing and see if it works. You may refer to the link below for the instructions:
http://kb.netgear.com/app/answers/detail/a_id/1086
Dexter
Community Team
DexterJB
Sep 18, 2015NETGEAR Moderator
Hi INFTeamLeader,
Dexter
Community Team
INFTeamLeader
Sep 18, 2015Aspirant
AMAZING. MAC Spoofing worked. So now the question is, is that an issue with my router or the ISP? I use Wave Broadband and never have seen this issue before.
- DexterJBSep 18, 2015NETGEAR Moderator
Hi INFTeamLeader,
It is possible that the MAC spoof was not applied correctly and needed to be re-synced with the ISP.
Dexter
Community Team
