INFTeamLeader
Sep 17, 2015Aspirant
Unable to access a website on a R6300
Yesterday a website I frequent became unavailable. i get ERR_CONNECTION_TIMED_OUT. It is 69.73.172.48(www.waguns.org). I can tracert to it but not PING it. When I connect directly into my broadband ...
- Sep 18, 2015
Hi INFTeamLeader,
If you are with a cable ISP, you may try performing MAC spoofing and see if it works. You may refer to the link below for the instructions:
http://kb.netgear.com/app/answers/detail/a_id/1086
Dexter
Community Team
TheEther
Sep 18, 2015Guru
Yes that's possible but it wouldn't explain why it didn't work without any MAC spoofing. Oh well, I have no explanation. A change in Layer 2 addressing should not affect Layer 3 in this instance.
