crzylikafx
Jan 22, 2021Aspirant
Unable to access cloud storage device outside of home
Hi, I have an orbi wifi mesh system and just purchased and set up a personal cloud storage device. I can't access the cloud storage outside of my home.I tried to set up port forwarding on the orbi router. When I go open the port for the cloud storage it is listed as a different IP address in Orbi's port forwarding than it is on the personal clouds link. As a result, I can't use the IP address for the cloud storage, when I used the IP address that Orbi sees it as, I can't access the device. How do I set it up to access the device given this issue?
- crzylikafxAspirant
Update (Didn't see how to edit original post) - In port forwarding the ip addresses do match up correctly now. But I still can't access it externally. The protocol is tcp/udp, port is 9000 and the internal external port is checked to match. What am I doing wrong?
> [...] I have an orbi wifi mesh system [...]
Firmware version(s)? Connected to what?
> [...] a personal cloud storage device. [...]
Not a very detailed description of anything. Maker? Model number?
At least one of us might want to read the documentation for it.> [...] I can't access the cloud storage outside of my home. [...]
"access" _how_? "can't" is not a useful problem description. It
does not say what you did. It does not say what happened when you did
it. As usual, showing actual actions (commands) with their actual
results (error messages, LED indicators, ...) can be more helpful than
vague descriptions or interpretations.> [...] I tried to set up port forwarding on the orbi router. [...]
Why? Are you following some set of instructions or other? "tried"
_how_, exactly? See "not a useful problem description [...]", above.> [...] When I go open the port for the cloud storage it is listed as a
> personal clouds link. [...]With my weak psychic powers, I can't see either of those addresses.
What's a "the personal clouds link"?
> [...] I still can't access it externally. [...]See "not a useful problem description [...]", above.
> [...] What am I doing wrong?
What, exactly, are you doing?
V.2.5.1.16 The orbi acts as my router that is connected to my Fios Quantam Router
Buffalo Linkstation 210
Via internet access - http://buffalonas.com/LVDesigns/
I receive the following error message - "The Buffalo NAS Device Could Not Be connected. Check the settings of the buffalo NAS device and the router."
_how_, exactly? See "not a useful problem description [...]", aboveI'm following a set of instructions. According to Buffalo Support the router is blocking access. That Port 9000 is not open. That I need to open it on my router so that I can access the NAS device over the internet.
What's a "the personal clouds link"?No longer an issue. The link is the link I provided in this response.
