anthgav77
Aug 26, 2021Aspirant
Unable to access configuration screen
Hi WAC124\AC2000 Firmware version 1.0.4.6 This device is registered within my Netgear account. I started having wifi connection issues with this device after about a years use. I decided to f...
- Aug 26, 2021
To be clear, disconnect the WAN port from the internet and then log into the WAC124. It will log in using the local login instead of SSO. You'll need to do that for every login unless you block the WAC124 from accessing the internet.
indi-tech
Aug 26, 2021Star
So Netgear's SSO is broken, at least for the WAC124. So the trick is how to acess the web GUI after Netgear broke it. You can still access the GUI after disabling the WAN connection, but then how to use the AP? Well, firewall it.
We used a Cisco Meraki MX to firewall the WAC124 and prevent it from accessing the internet. Just the WAC124, all devices connected to it still have internet access. So the WAC124's OS is prevented from accessing the internet and thus the end user is presented with the local login instead of SSO.
There you go, kick that failed SSO to the curb! Get your WAC124 back without paying support money to Netgear.
