chaitanya92
Mar 01, 2016Aspirant
Unable to access my network after i reset my Router
HI, i have recently tried to reset my router to factory defaults and i have followed the procedure to reset after doing so my network says it is secured and i need to enter a password to access it wh...
- Retired_MemberMar 01, 2016
use defaults...... they are on router label
Retired_Member
Mar 01, 2016use defaults...... they are on router label
- chaitanya92Mar 01, 2016Aspirant
N150 WIRELESS ROUTER WNR612v3
NETGEAR88
Hi , i think once we reset router everything changes to default i.e,wifi name as highlighted in attached pic and it's status to open instead of secured if i am wrong please correct me. For instance i have tried that default password as quoted on router.
Regards.
netgear88 is secured ....default WIFI settings are secure...only your router uses the default passphrase for wifi.
Log in and change router password if your worried about it.
Thanks for your kind reply but the thing is my issue hasn't solved yet.
Regards.
