chaitanya92's avatar
chaitanya92
Unable to access my network after i reset my Router
HI, i have recently tried to reset my router to factory defaults and i have followed the procedure to reset after doing so my network says it is secured and i need to enter a password to access it wh...
  • Retired_Member's avatar
    Retired_Member
    Mar 01, 2016
    use defaults...... they are on router label
