kanakakai
Sep 14, 2025Aspirant
Unable to access my router...
I have a WNDR3700v3 router. I am direct connected to it. i am unable to access my router using: routerlogin.net routerlogin.com http://192.168.1.1 http://192.168.0.1 I have deleted web c...
kanakakai
Sep 18, 2025Aspirant
Darren! That's it! Thanks so much for your awesome help! :)
- FURRYe38Sep 18, 2025Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-routerEnjoy. 📡
