kanakakai
Sep 15, 2025Aspirant
Unable to access my router...
I have a WNDR3700v3 router.
I am direct connected to it.
i am unable to access my router using:
routerlogin.net
routerlogin.com
http://192.168.1.1
http://192.168.0.1
I have deleted web caches and used multiple browsers.
Any help would be amazing.
Thanks!
attached is the page it sends me to when i use the "routerlogin.___" method:
- kanakakaiAspirant
Darren! That's it! Thanks so much for your awesome help! :)
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-routerEnjoy. 📡
- DarrenMSr. NETGEAR Moderator
Do you have another router connected to the network? If so, it might be assigning the WNDR3700 a different IP address. If you need to connect to that router's GUI and look at the connected devices, and then use the IP address it assigned to the router in the web browser. You may also want to try 192.168.100.1
Thanks
DarrenM
