ggarner1995
Jul 31, 2021Aspirant
Unable to access readyshare drive from LAN ports
The network setup that I have is as follows: Modem --> Orbi --->R6220---> PC |---------> PC |---------> USB Storage The...
ggarner1995
Aug 01, 2021Aspirant
I already use the DHCP address reservation to reserve 192.168.1.20 as the address, so the Orbi's DHCP will always assign that address. As for name resolution, it's not actually the problem (the broadcast is used to resolve the local hostnames), but you're correct that this has nothing to do with the wireless ports. It still happened when I connected the computer over the wireless.
I decided to capture the traffic with wireshark and here is what I found (first column time; r6220 is 192.168.1.20, and I'm 192.168.1.9):
Wireshark
ggarner1995
It appears that the image failed to appear; link to image: https://imgur.com/a/bYLPZtk
- michaelkenwardAug 02, 2021Guru - Experienced User
It may be some time before the images land. To ensure that you aren't posting anything naughty, a Netgear moderator has to approve the pictures.
You can attach images to messages without any delay. That is safer than expecting people to follow possibly dodgy links to other sites.
