vickyg2003
Jan 10, 2020Aspirant
Unable to access routerlogin.net
Hello I'm a not a tech, I'm a beginner and senior citizen too, so be kind. AT&T U-verse 5268ac GATEWAY dual band router AT&T Cisco VEN401-AT Access Point (talks to TV boxes) NETGEAR WNR2500RP-...
- Jan 14, 2020
Bit the bullet, and did a hard reset of the GATEWAU which broke the link to the NETGEAR, and was able to login wirelessly to the Gateway and restore the SSID's, and all is good with computers, printers and TVs, and can get to routerlogin.net or by using the assigned IP address.
I'm worried because I just got a message from A&T about my GATEWAY settings being changed, and action may be required. If they take action, I'll probably be in the same boat I've been in for the past 3 weeks!
The whole thing problem was an AT&T setting that was preventing me from reaching both my NETGEAR and the GATEWAY.
michaelkenward
Jan 10, 2020Guru - Experienced User
NETGEAR WNR2500RP-v2 (used as what I think you'd call a wireless bridge)
That is a complicated portfolio of kit.
How is it all connected?
Is the Access Point plugged into the Gateway?
The WNR2500RP is now an ageing (2012), and basic router.
If you have an Ethernet outlet on the Gateway, you might find it easier to dump the WNR2500RP abd replace it with Powerline Ethernet. You can then use that for wired Ethernet to printers and computer. Powerline is also good for Smart TVs that have Ethernet.
Simplifying the network and getting back to basics might make life easier.
vickyg2003
vickyg2003 wrote:
The WNR2500RP is connected via 5GHz WiFi
vickyg2003 wrote:
It was my understanding that Powerline connections had to be on the same circuit
But mine are on different breakers.
In the meantime I had a friend come over with a laptop. I went up and down the GATEWAY settings and couldn't find anything that sounds like a prevent wireless access and when I connected it through WiFi it would not work.
I've been doing this through wifi since I got the router.
I suppose they pushed out an update.
- michaelkenwardJan 11, 2020Guru - Experienced User
vickyg2003 wrote:It was my understanding that Powerline connections had to be on the same circuit
Spot on there. But I have never come across a single property that has separate mains circuits.
Not sure what you mean by "breakers". If these are circuit breakers that act as fuses, then they should be on the same switch box with the same mains input. (Flick one switch on the box and the whole place loses power.) In which case they are on the same circuit.
I'm still having trouble understanding what connects to what. Probably because I have no idea what AT&T U-verse wireless TV is. I assume that it is something separate from your Internet service. So your challenge is to connect to the Internet with one wifi network and the TV with a separate wifi network.
I doubt if there are many people here who use AT&T U-verse wireless TV. It isn't something I have seen mentioned before.
- vickyg2003Jan 11, 2020Aspirant
AT&T Uverse is delivered via fiber optics. Unlike a cable TV - interent, where the cable is split one to Modem Router, and the other part to the TVs. This service comes in to the AT&T GATEWAY which is the main MODEM ROUTER. The TV signal is then distributed via an AP access point and a whole house DVR that occupy 2 of the ethernet ports. The TV setop boxes other than the DVR are all wireless and connected to the AP. The GATEWAY Modem Router router also handles the internet access.
Down the hall is my office where I have 2 Ethernet printers, a computer, and there is no way to get an ethernet cable all this way that is not going to look tacky. I took the NETGEAR Box and established a Wireless connection to the GATEWAY and provided ethernet access to my computer and printers. All my wireless devices can print to my printers, and internet access has been lightning quick.
The problem is that now all of a sudden I can't get to NETGEAR ROUTERLOGIN.NET which is connected with ETHERNET unless the GATEWAY is down, and the whole point of logging into the NETGEAR is to re-establish wireless communication with the GATEWAY, and I no longer can reach the GATEWAY wirelessly.
Oh and I thought when Powerline talked about being on the same circuit they were talking about the circuit for a circuit breaker. Calling it the same circuit if they meant the same breaker box seems like odd terminology.
vickyg2003 wrote:Oh and I thought when Powerline talked about being on the same circuit they were talking about the circuit for a circuit breaker. Calling it the same circuit if they meant the same breaker box seems like odd terminology.
There are many ways of defining a circuit. Ultimately, the whole country sits on one "circuit".
In the case of Powerline, the circuit is the one that feeds your property. In apartments people sometimes find that their Powerline plugs talk to the neighbour's plugs.
If it all goes back to the same fuse box and power meter, that's one circuit. There may be various loops on that circuit, upstairs and downstairs, for example, but they will all talk to each other when it comes to Powerline.
If there is more than one switch box, that can get in the way of a clean circuit. For example, my office network has a fuse box with a trip switch connected to a separate fuse box and switch in the house. Powerline does cross the joins but the signal, and speed, is significantly slower.
On the wifi issue, I wonder if it is an IP address thing. ROUTERLOGIN.NET is not the only way in. If you know the IP address of the WNR2500RP, then you can throw that at your browser. By default it should be: 192.168.1.1
