vickyg2003
Jan 10, 2020Aspirant
Unable to access routerlogin.net
Hello I'm a not a tech, I'm a beginner and senior citizen too, so be kind. AT&T U-verse 5268ac GATEWAY dual band router AT&T Cisco VEN401-AT Access Point (talks to TV boxes) NETGEAR WNR2500RP-...
- Jan 14, 2020
Bit the bullet, and did a hard reset of the GATEWAU which broke the link to the NETGEAR, and was able to login wirelessly to the Gateway and restore the SSID's, and all is good with computers, printers and TVs, and can get to routerlogin.net or by using the assigned IP address.
I'm worried because I just got a message from A&T about my GATEWAY settings being changed, and action may be required. If they take action, I'll probably be in the same boat I've been in for the past 3 weeks!
The whole thing problem was an AT&T setting that was preventing me from reaching both my NETGEAR and the GATEWAY.
michaelkenward
Jan 11, 2020Guru - Experienced User
vickyg2003 wrote:
It was my understanding that Powerline connections had to be on the same circuit
But mine are on different breakers.
Spot on there. But I have never come across a single property that has separate mains circuits.
Not sure what you mean by "breakers". If these are circuit breakers that act as fuses, then they should be on the same switch box with the same mains input. (Flick one switch on the box and the whole place loses power.) In which case they are on the same circuit.
I'm still having trouble understanding what connects to what. Probably because I have no idea what AT&T U-verse wireless TV is. I assume that it is something separate from your Internet service. So your challenge is to connect to the Internet with one wifi network and the TV with a separate wifi network.
I doubt if there are many people here who use AT&T U-verse wireless TV. It isn't something I have seen mentioned before.
vickyg2003
Jan 11, 2020Aspirant
AT&T Uverse is delivered via fiber optics. Unlike a cable TV - interent, where the cable is split one to Modem Router, and the other part to the TVs. This service comes in to the AT&T GATEWAY which is the main MODEM ROUTER. The TV signal is then distributed via an AP access point and a whole house DVR that occupy 2 of the ethernet ports. The TV setop boxes other than the DVR are all wireless and connected to the AP. The GATEWAY Modem Router router also handles the internet access.
Down the hall is my office where I have 2 Ethernet printers, a computer, and there is no way to get an ethernet cable all this way that is not going to look tacky. I took the NETGEAR Box and established a Wireless connection to the GATEWAY and provided ethernet access to my computer and printers. All my wireless devices can print to my printers, and internet access has been lightning quick.
The problem is that now all of a sudden I can't get to NETGEAR ROUTERLOGIN.NET which is connected with ETHERNET unless the GATEWAY is down, and the whole point of logging into the NETGEAR is to re-establish wireless communication with the GATEWAY, and I no longer can reach the GATEWAY wirelessly.
Oh and I thought when Powerline talked about being on the same circuit they were talking about the circuit for a circuit breaker. Calling it the same circuit if they meant the same breaker box seems like odd terminology.
- michaelkenwardJan 11, 2020Guru - Experienced User
vickyg2003 wrote:Oh and I thought when Powerline talked about being on the same circuit they were talking about the circuit for a circuit breaker. Calling it the same circuit if they meant the same breaker box seems like odd terminology.
There are many ways of defining a circuit. Ultimately, the whole country sits on one "circuit".
In the case of Powerline, the circuit is the one that feeds your property. In apartments people sometimes find that their Powerline plugs talk to the neighbour's plugs.
If it all goes back to the same fuse box and power meter, that's one circuit. There may be various loops on that circuit, upstairs and downstairs, for example, but they will all talk to each other when it comes to Powerline.
If there is more than one switch box, that can get in the way of a clean circuit. For example, my office network has a fuse box with a trip switch connected to a separate fuse box and switch in the house. Powerline does cross the joins but the signal, and speed, is significantly slower.
On the wifi issue, I wonder if it is an IP address thing. ROUTERLOGIN.NET is not the only way in. If you know the IP address of the WNR2500RP, then you can throw that at your browser. By default it should be: 192.168.1.1
- vickyg2003Jan 12, 2020Aspirant
tHA
vickyg2003 wrote:On the wifi issue, I wonder if it is an IP address thing. ROUTERLOGIN.NET is not the only way in. If you know the IP address of the WNR2500RP, then you can throw that at your browser. By default it should be: 192.168.1.1
The NETGEAR WNR2500RP gets its ip address automatically from the GATEWAY. That is why I was trying to login to the GATEWAY, to see what the WNR2500RP's IP address is. I haven't been able to do that since Dec 27, when wireless access to the GATEWAY stopped working. If I power down both routers and reboot the WNR2500RP I can access the box by either Routerlogin.net or its default IP address, but what's the point. It won't work when the GATEWAY is up, which is what I need it for.
- vickyg2003Jan 14, 2020Aspirant
