vickyg2003's avatar
vickyg2003
Unable to access routerlogin.net
Hello I'm a not a tech, I'm a beginner and senior citizen too, so be kind.   AT&T U-verse 5268ac GATEWAY dual band router AT&T Cisco VEN401-AT Access Point (talks to TV boxes) NETGEAR WNR2500RP-...
  • vickyg2003's avatar
    vickyg2003
    Jan 14, 2020
    Bit the bullet, and did a hard reset of the GATEWAU which broke the link to the NETGEAR, and was able to login wirelessly to the Gateway and restore the SSID's, and all is good with computers, printers and TVs, and can get to routerlogin.net or by using the assigned IP address.
    I'm worried because I just got a message from A&T about my GATEWAY settings being changed, and action may be required.  If they take action, I'll probably be in the same boat I've been in for the past 3 weeks!
    The whole thing problem was an AT&T setting that was preventing me from reaching both my NETGEAR and the GATEWAY.
