krysztof
Dec 07, 2020Aspirant
Unable to activate LAN ports (Link down) Firmware: V1.1.0.100_1.0.1
Hello, The LAN-ports on my R6220 is incative. When connecting an ethernet cable from any of the routers ethernet ports to computer, Windows does not detect any cable with the network interface ca...
- Dec 07, 2020
Time for the ubiquitous factory reset - not sure this can resolve this issue. Is the router still under warranty?
schumaku
Dec 07, 2020Guru - Experienced User
With the link LED coming up on the suggested loopback-test, but not when connecting your computer the suspicion is that the computer network adapter is disabled or some power settings prevent enabling it so the Ethernet can't be enabled.
krysztof
Thanks for replying.
I forgot to add information in the original post that no other computers gets connection through the LAN ports either.
The NIC's on the computers are enabled and do not have power settings enabled.
- schumakuDec 07, 2020Guru - Experienced User
- krysztofDec 08, 2020Aspirant
I did a backup of the router configuration, performed a factory reset and loaded the old configuration.
The LAN ports are now active when connecting ethernet cables. Thanks.
