agrarDATA's avatar
agrarDATA
Unable to add custom port forwarding service
See screenshots below. I am unable to add port 5060, because there is a port-conflict with another service
  • Solution that worked for me: Remove all port-forwarding-rules, set 5060 first and then the others
  • FURRYe38's avatar
    What browser are you using?
    Try a factory reset and setup from scratch. Be sure to not enable any security or access controls.
    • agrarDATA's avatar
      agrarDATA
