antipatico's avatar
Oct 23, 2022
Unable to backup to Time Machine
I'm unable to conduct a backup to Time Machine. I'm on macOS Big Sur 11.7.
These are the error messages I've received:
1. Time Machine:
Unable to complete backup. An error occurred while creating the backup folder.
2. Bitdefender Antivirus for Mac:
Feature: Anti-Ransomware
An unauthorized app attempted to access your backups.
App: /System/Library/Core Services/backup.bundle/Contents/Resources backup
We blocked the app to prevent it from altering the content of your backups.
Hopefully someone has experienced this issue and can provide a fix.
r/Wayne
    • FURRYe38's avatar
      Something to contact Apple about since Time Machine is there product.
  • plemans's avatar
    What netgear device do you have?
    Kind of key.
    Some of the routers used to have time machine support but its been pulled in later firmwares due to a security issue with it.
    but tough to know without knowing what device you have and what firmware is on it
    • antipatico's avatar
      antipatico
      Star
      Hello,
      Devices:
      Modem: CM1000
      Router: BR750
      Fyi: My backups are to an external HD via firewire port from Mac to HD. I also emailed Bitdefender customer support with screen shots of the error messages and a BD profiler report.
      r/Wayne
      • michaelkenward's avatar
        michaelkenward
        antipatico wrote:
        Devices:
        Modem: CM1000
        Router: BR750
        We can ignore the CM1000. That's just a modem.
        I can't find "BR750" in the Netgear catalogue.
        RBR750?
        That's an Orbi device
        I see no hint that Orbi has ever supported time machine. Does any Orbi do that?
        Maybe time machine support doesn't depend on the router. But you may have to set it up properly.
        Did you follow thee suggestion from FURRYe38 and ask the people at Apple?
        How about this?
        Search - NETGEAR Communities – Time Machine
        If the RBR750 is what you own, try looking in the right place.
        While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
        You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
        Orbi - NETGEAR Communities
        You might like to search there for messages related to your problem.
        In the meantime you could visit the support pages:
        Support | NETGEAR
        Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
        Check for various troubleshooting tips.
        You may have done this already. I can't tell from your message.
        I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
