pjhyd4
Nov 09, 2016Tutor
Unable to change network password
Recently I upgrded my firmware. Earlier I could change my network password whenever I wanted. After I upgraded the firmware this is the first time I am trying to change my network password. When I ty...
- Nov 09, 2016
Sir,
My problem is solved when I downloaded 1.0.0.18 and replaced 1.0.0.26.
I got the link https://www.netgear.com/support/product/WNR612v3?cid=wmt_netgear_organic#download when I searched in google typing "downgrade netgear firmware wnr612v3"
This is for the information of netgear company to fix their bug.
Thank you
netwrks
Nov 09, 2016Master
You can downgrade, but you should probably reset the router to factory default first and reconfigure from scratch.
pjhyd4
Nov 09, 2016Tutor
Sir,
I tried resetting the router to factory default several times. But, I still could not change my network password. I could only change the router password. I believe there is some bug in the recently upgraded firmware. I wish to downgrade. Kindly help me downgrade. Please let me know the procedure.
Thank you
Philip John
- pjhyd4Nov 09, 2016Tutor
Sir,
Thank you
- netwrksNov 09, 2016Master
In the future.. You can find downloads, at the top right of this page..
