vkulkarni_syd
Oct 17, 2022Follower
Unable to connect Netgear AC1200 6150v2 WiFi Extender to Telstra Smart Modem 3
Hi, I had the netgear wifi extender connected to Optus NBN router. Since changing to Telstra NBN with the Smart Modem 3 router, I have been unable to get the netgear device to connect with the smart...
Oct 17, 2022Guru - Experienced User
Did you set it up using the push button WPS option?
If so, factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
