Mushy25
Sep 23, 2020Aspirant
Unable to connect R6400 router to modem after software upgrade attempt using NETGEAR Genie
We tried to upgrade our R6400 (5 years old but working fine) router on the Network Genie due to slow speeds and drop outs. Internet speeds directly from modem did not vary much. I noticed the the "Ge...
Sep 23, 2020Guru - Experienced User
what are the led's on it doing?
are you able to ping the router
- Mushy25Oct 01, 2020AspirantAll LEDs are working as normal. We’re getting service to the modem and can connect via Ethernet.
Ping and speed are ok.
It is going to the router. But we are getting no wifi signal. This all happened after a failed software update directly from the Netgear genie site.- plemansOct 01, 2020Guru - Experienced User
so you can ping the router and it works hardwired.
Its just wirleess that doesn't work?
Does it broadcast and you can't connect?
Can you connect and it says "connected, no internet"
Does it not even broadcast?
- Mushy25Oct 01, 2020AspirantIt would not connect up when hardwired to laptops.
It was not visible at all. It was not broadcasting.
Could not be found on any device. This was also the same s for the guest network we had set up.
It looks like it works with all light correct. But nothing is coming out. No wifi signal or Donald when connected up with cable.
Separate modem works fine. Internet connection tested ok.
